I am having a lot of packet loss and general outages on my internet. I currently have comcast and any hopes of having them fix this issue have been shot down. They have visited my house 3 times in the past few months only for each of them to try something new and have the issue come back the next night. The device is running on a hard line.
I have Comcast Business Internet at one site and have been surprised at how well it has been working and how pro-active they are - they occasionally call and say "We see low signal levels - would you mind if we came out and looked at it?" From what I hear, their residential support is nowhere as good.
The first thing you should do is isolate the problem to your network or their network. When you are experiencing the problem, disconnect everything from the LAN port on your cable modem and then plug in a single computer with a direct cable (no switch, etc.). The computer will need to be set to acquire an Internet address via DHCP (it probably is already). Do
not power cycle or reset your modem - we'll want to look at some of its data later on.
Now, repeat the tests (speedtest.net, pingtest.net, etc.) and see if you still have the problem. If you do, then it is not on your network. If you don't, then either you have a problem on your network or you just have very bad timing, where the problem cleared while you were switching things over.
If you do still have a problem, you'll want to capture some information from your cable modem. Point your browser to
http://192.168.100.1. You should see a page with a Surfboard logo on the top left (since you have a Motorola / Arris modem). There will be tabs along the top. On my modem, they are: Status / Signal / Addresses / Configuration / Logs / Open Source / Help. It may be helpful to take a screen capture of the information (among other things, you can show it to your Comcast tech next time).
We want to look at Signal first. You will see one or more columns for "Downstream". For each column, note the "Signal to Noise Ratio" and "Power Level". These should be relatively consistent across all of the columns (if more than one). Lower on that page you will see one or more columns for "Upstream". Note the "Power Level" in each column there as well. Even further down the page, look for "Signal Stats (Codewords)". We don't care about absolute numbers here, just that for each column "Total Unerrored Codewords" should be a really big number and "Total Correctable Codewords" and "Total Uncorrectable Codewords" should be a lot smaller. For example, in one of my columns I have 10712765113, 616, and 727.
Now, move to the Logs tab and copy all of that data. It is normal for the logs to have some scary-sounding things in them. Rather than try to describe what is bad and what isn't, just post the log here.
Lastly, move to the Help tab. For completeness, copy the info from the top left of the page and paste it here. You may want to x out the serial number - that's fine.
Post that info here and I'll look at it.
Continue reading my next reply for other things you can look at.
