I recently purchased a new switch (Dell 2716), and have been playing around with my server a bit. Unfortunately, my results this far aren't overly satisfying. I wasn't expecting full Gbit speeds with the current setup I have, but I was expecting a lot more than I'm getting.
First things first, my NICs aren't the best. This is just a fact of life right now, as I'm in the process of hopefully upgrading some things. My server has a Realtek 8111 (boo!) and my Laptop has a JMicron something-or-other (not 100% sure what it is). Both these computers have 4GB of RAM. Both computers are connected via Cat6 patch cables to the Dell switch. No configuration has been done to any of these 3 devices.
I've done a bit of testing, so I do have some numbers and results to throw out there. First things first, here's iperf:
That all pans out (I did the test running in both directions as well, forget what it's called, and got the same results. Just didn't get a screenshot).
Next is the benchmark on my mirrored array (2x Samsung F4 2TB's) on my server:
Probably not the best method of testing, but it should still be able to nearly saturate a Gbit network, so that's obviously not the issue.
I ran IOzone on my Laptop, don't really know how to decipher the results, so here they are:
If you guys want me to run something else just lemme know.
Finally, transferring a large file to/from my Server/PC. Not a real accurate test, but this is just real world results.
As you can see, those results are quite pitiful.
I don't really know where to go from here next. Changing NICs isn't an option at this point. I'm running Cat6 and a high-end Gbit switch, so that shouldn't be an issue. At this point I'm thinking it has to be primarily configuration, and maybe my laptop drive is slow as well. As I mentioned, my server/Laptop have default network configurations, and the Dell 2716 is at system defaults currently.
Any suggestions on how I can improve my speeds?
Thanks,
- Jesse
Thanks,
- Jesse
