Inconsistency detected by ld.so
basilisk
HI All,
I am logged into my ASUS GT-AX6000 router running Merlin FW 3004.388.8 using kitty 0.76.1.13p.
When I run amtm I get the message "Inconsistency detected by ld.so". See attachment. Theses message just keep repeating until I press Ctrl-C.
I have rebooted the router but it didn't help.
Any help will be appreciated.
John
If it were me I'd:
Back my settings up, reflash the router, and perform a factory reset using the WPS method before setting everything back up. I'd also be worried that doing what I've just said could potentially leave you with a none functioning router (I am a panicker)!
Good Luck!
I would rename or delete the entware folder on the USB and reinstall Entware through amtm ep option.
Thanks for the responses. I took your advice dave14305. After reinstalling entware and diversion all seems ok again.
It would be nice to know the cause.
Anyhow I am back to normal. Thanks all.
Cheers
John
