init scripts are not being executed on startup
agneev
Hello all,
I'm running Voxel Firmware V9.2.5.2.37SF-HW on my RBK50.
A couple of days ago, I ran opkg update and opkg upgrade. Since then, I have noticed that scripts that are located in /etc/init.d/ do not start during boot anymore.
I have even created a simple script that starts these services and put it in /opt/scripts and it seems that this does not work either.
Any help is appreciated, thanks
- agneev
Hello all,
- agneev
Hello :)
Do you mean in /opt/etc/init.d/?
1) Check that you have /tmp/mnt/sda1/autorun/scripts/post-mount.sh on you optware disk, with this inside:
# Start optware services if /opt is linked
if [ -x /opt/etc/init.d/rc.unslung ]; then
    /opt/etc/init.d/rc.unslung start
fi
2) Then check that subdirectories in /opt are linked : ls -l /opt, that should give you something like this (more or less):
root@HERMES:/tmp/mnt/sda1/autorun/scripts$ ls -l /opt
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 bin -> /tmp/mnt/sda1/entware/bin
lrwxrwxrwx    1 root     root           20 Dec 23 12:03 bolemo -> /tmp/mnt/sda1/bolemo
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 etc -> /tmp/mnt/sda1/entware/etc
-rw-r--r--    1 root     root          855 Jan  1  1970 filelist
lrwxrwxrwx    1 root     root           26 Dec 23 12:03 home -> /tmp/mnt/sda1/entware/home
drwxr-xr-x    2 root     root          224 Jan  1  1970 leafp2p
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 lib -> /tmp/mnt/sda1/entware/lib
lrwxrwxrwx    1 root     root           29 Dec 23 12:03 libexec -> /tmp/mnt/sda1/entware/libexec
drwxr-xr-x    4 root     root          648 Jan  1  1970 rcagent
drwxr-xr-x    2 root     root          296 Jan  1  1970 remote
lrwxrwxrwx    1 root     root           26 Dec 23 12:03 root -> /tmp/mnt/sda1/entware/root
lrwxrwxrwx    1 root     root           26 Dec 23 12:03 sbin -> /tmp/mnt/sda1/entware/sbin
lrwxrwxrwx    1 root     root           29 Dec 23 12:03 scripts -> /tmp/mnt/sda1/entware/scripts
lrwxrwxrwx    1 root     root           27 Dec 23 12:03 share -> /tmp/mnt/sda1/entware/share
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 tmp -> /tmp/mnt/sda1/entware/tmp
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 usr -> /tmp/mnt/sda1/entware/usr
lrwxrwxrwx    1 root     root           25 Dec 23 12:03 var -> /tmp/mnt/sda1/entware/var
-rw-r--r--    1 root     root            9 Jan  1  1970 version
drwxr-xr-x    3 root     root          504 Jan  1  1970 xagent
3) Then check that you do have /opt/etc/init.d/rc.unslung
rc.unslug
is the script that runs everything executable inside /opt/etc/init.d/.
I'm trying to run another dnsmasq daemon. If I use a init.d script, it fails to work because the rc.func file checks for the process name.
I'm trying to instead, have a script run at startup that runs dnsmasq in the background. Where should I place the script so that it runs on startup?
root@orbi-gateway:~# ls -lh /opt/
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 bin -> /tmp/mnt/sda1/entware/bin
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 etc -> /tmp/mnt/sda1/entware/etc
lrwxrwxrwx    1 root     root          26 Dec  2 17:52 home -> /tmp/mnt/sda1/entware/home
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 lib -> /tmp/mnt/sda1/entware/lib
lrwxrwxrwx    1 root     root          26 Dec  2 17:52 root -> /tmp/mnt/sda1/entware/root
lrwxrwxrwx    1 root     root          26 Dec  2 17:52 sbin -> /tmp/mnt/sda1/entware/sbin
drwxr-xr-x    2 root     root         100 Feb 23 13:20 scripts
lrwxrwxrwx    1 root     root          27 Dec  2 17:52 share -> /tmp/mnt/sda1/entware/share
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 tmp -> /tmp/mnt/sda1/entware/tmp
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 usr -> /tmp/mnt/sda1/entware/usr
lrwxrwxrwx    1 root     root          25 Dec  2 17:52 var -> /tmp/mnt/sda1/entware/var
Here is one way :
Put your script for example at the root of the optware disk (or anywhere you want).
Then add a line at the end of /tmp/mnt/sda1/autorun/scripts/post-mount.sh to run your script (with the full path to your script):
Bash:
# Start custom script
[ -x /tmp/mnt/sda1/myscript.sh ] && /tmp/mnt/sda1/myscript.sh
Then, each time you reboot or plug the optware disk, it will launch you script.
