BlackMage
how can i install entware(with opkg package manager) from optware(ipkg package manager)?
the current state of my opkg manager is:
the command amtm outputs at end:
but state of the ipkg manager is:/opt/bin/opkg: line 1: syntax error: unexpected "("
# ipkg list_installed
bzip2 - 1.0.6-1 -
expat - 2.0.1-1 - XML Parser library
gdbm - 1.8.3-4 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines.
gettext - 0.14.5-2 - Set of tools for producing multi-lingual messages
ipkg-opt - 0.99.163-10 - The Itsy Package Manager
libcurl - 7.24.0-1 - Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, GOPHER, TELNET, DICT, FI
libdb - 4.2.52-3 - Berkeley DB Libraries
libevent - 2.0.20-1 - libevent to implement an event loop
libiconv - 1.13.1-1 - Converts between character encodings.
liblzma0 - 5.0.5-1 - A free general-purpose data compression software with high compression ratio
libpar2 - 0.2-6 - A library for performing common tasks related to PAR recovery sets
libsigc++ - 2.2.3-1 - libsigc++ implements a typesafe callback system for standard C++.
libstdc++ - 6.0.2-6 - Standard C++ library, needed for dynamically linked C++ programs
libxml2 - 2.7.8-1 - Libxml2 is the XML C parser and toolkit developed for the Gnome project.
lua - 5.1.5-1 - Lua is a powerful light-weight programming language designed for extending applications.
nano - 2.2.6-1 - A pico like editor
ncurses - 5.7-3 - NCurses libraries
ncursesw - 5.7-2 - NCurses libraries with wide char support
openssl - 0.9.8v-2 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
pcre - 8.31-1 - Perl-compatible regular expression library
perl - 5.10.0-6 - Practical Extraction and Report Language.
python3 - 3.2.3-3 - Python is an interpreted, interactive, object-oriented programming language.
readline - 6.1-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
spawn-fcgi - 1.6.3-1 - spawn-fcgi is used to spawn fastcgi applications
sqlite - 3.8.1-1 - SQLite is a small C library that implements a self-contained, embeddable, zero-configuration SQL database engine.
transmission - 2.82-1 - Lightweight BitTorrent client and daemon, with web interface bundled.
uclibc-opt - 0.9.28-1 - micro C library for embedded Linux systems
wget - 1.12-2 - A network utility to retrieve files from the Web
wxbase - 2.8.12-1 - wxbase is a basic (non-windows) part of wxWidget toolkit
xz-utils - 5.0.5-1 - A free general-purpose data compression software with high compression ratio
zlib - 1.2.5-1 - zlib is a library implementing the 'deflate' compression system.
Successfully terminated.
Getting from fwupdate.asuswrt-merlin.net
! Module entware.mod download failed
! using fallback server diversion.ch
