installation of entware
adrianmak
I followed this guide to install entware on my n66u
https://github.com/RMerl/asuswrt-merlin/wiki/Entware
#entware-setup.sh
no error
and then I installed python
#opkg install python
no errors too.
I could run python interactive interpreter
However, when I did a reboot of the router, python, opkg command not found
I compared the path after entware and python installation and the path with router rebooting,
both search path are the same.
What's wrong ?
I didn't find this option
enable JFFS custom scripts and configs
under administration -> system page
only with these options
Enable JFFS partition
Format JFFS partition at next boot
I found that the /tmp/opt is pointed to /tmp/mnt/sda1/asusware
instead of /tmp/mnt/sda1/entware
Should I have to execute the entware-setup.sh script under directory /tmp/mnt/sda1/asusware ?
You can't run Download Master/Optware at the same time as Entware. You need to uninstall it and remove any asusware directories and then set up Entware again.
i figured out the issue.
I did
touch /mnt/sda1/asusware.arm/.asusrouter
this step
I removed this file and re-run the script.
no more issue now
