Installed Entware/Optware package on flash (without USB)
snowman
Just started my journey on open source firmware for SOHO router(DD-Wrt/OpenWrt).
Very glad I find this forum.
ASUSWRT Merlin seems to have best of both world between factory(wifi driver)/OpenSource(features).
Is it possible to installed Entware/Optware package on flash (without USB)?
This is on:
ASUS RT-AC78R running Firmware: 378.51
There are more than enough space for the packages I wanted to play with.
I want to setup a couple to play with; so if I can do it without USB would be icing on the cake.
David
admin@RT-AC87R-xxxx:/tmp/home/root# df -m
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/root 35 35 0 100% /
devtmpfs 125 0 125 0% /dev
tmpfs 125 9 116 7% /tmp
/dev/mtdblock4 63 2 61 3% /jffs
cat /proc/partitions
major minor #blocks name
31 0 512 mtdblock0
31 1 1536 mtdblock1
31 2 63488 mtdblock2
31 3 61847 mtdblock3
31 4 64256 mtdblock4
31 5 1280 mtdblock5
Yes, you can install directly to the JFFS partition.
Just enable SSH and use any number of utilities to create or edit files on there.
Thanks!!
Can you elaborate a bit?
Which opkg binary should I use? and what about supporting libraries?
TTT.
How does the /opt work in asuswrt?
In Merlin Wiki and Asus website: It seems like USB is a hard requirement?
./entware_install_arm.sh
Info: Checking for prerequisites and creating folders...
mkdir: can't create directory '/opt': File exists
mkdir: can't create directory '/opt/bin': No such file or directory
mkdir: can't create directory '/opt/etc': No such file or directory
mkdir: can't create directory '/opt/include': No such file or directory
mkdir: can't create directory '/opt/lib': No such file or directory
mkdir: can't create directory '/opt/sbin': No such file or directory
mkdir: can't create directory '/opt/share': No such file or directory
mkdir: can't create directory '/opt/tmp': No such file or directory
mkdir: can't create directory '/opt/usr': No such file or directory
mkdir: can't create directory '/opt/var': No such file or directory
mkdir: can't create directory '/opt/': No such file or directory
