Installing asusware to jffs - Resize jffs partition?
Grump
Is it possible to resize the jffs partition? I recall reading it could support 90MB but it's only set to 32MB. I didn't want to dedicate a USB stick to asusware because I only wanted a couple of packages (and I'm stubborn.) 64MB instead of 32MB would really add some breathing room.
How to install asusware to /jffs for those wondering...
This is on an RT-AC66U, it might be different for other models...
nvram set apps_dev="mtdblock5" # check "mount" for jffs mount
/usr/sbin/app_base_packages.sh
ipkg update # ignore asus 404 errors
ln -s /jffs/asusware /tmp/opt
Setup /opt on reboot
ipkg install nano
nano /jffs/scripts/services-start (or vi if you want)
#!/bin/sh
Resizing JFFS would require you to modify the kernel code, and recompiling the firmware.
ipkg install nano
#!/bin/sh
Thank you!
