Hi All
Sort of a checking my checklist and trying to make sure I get things right
I've had an AC86u for ages and actually bought the AX86uPro a long while ago but just never found time to make the switch/upgrade and the longer I left it the more daunting it seemed as more and more devices (heating, AC etc etc) all connect to the WiFi setup
So:
1. Get latest stable AX86uPro firmware
2. Swap out routers and immediately flash to the d/l 3.0.0.6 firmware for the new router and do a factory reset then start setting it up
2a. Do QIS and add in the settings for the static IP I have for this router from my ISP
3. My current set-up has separate SSIDs for 2.4 & 5Ghz but now I should just use 1 SSID and use smart connect is that correct? Searching the forum I seem to find conflicting advice on this? I'm nervous because some of my devices (heating control and aircon wifi) connect only to 2.4Ghz
I figure in principle when using new tech with a new network better to try the modern way of doing things rather than legacy approach but advice welcomed
4. Do I really need to manually set the channels for 2.4/5Ghz ? Happy to play around if problematic but if I'm giving myself time to srt it up "properly" from the off just useful to know what can predominantly be left to default and which you need to tweak for optimL performance (improving wifi range definitely a desire)
5. Then add in MAC for the various devices so they maintain the fixed IPs i set them up with and away we go
6. I'll probably see how I go with this wifi performance but probably next step will be connect the AC86u upstairs via a network switch in spare room to establish a MESH network
Any obvious silly things I've overlooked please? It's been a LONG while since I've messaged around with any of this
So:
