Installing Pyload Entware
becamo
Asus RTN66U
Merlin Firmware:3.0.0.4.374.39
1 SD 8gigas card intalled ext2 formated
2 USB disk NTFS Formated
JFFS is on
Installed entware on the sd card
Trying to install pyload
This is what I get
router@RTAsus:/tmp/mnt/sd# opkg install pyload
Installing pyload (0.4.9-1) to root...
Downloading http://wl500g-repo.googlecode.com/sv...oad_0.4.9-1_en
tware.ipk.
ware.ipk.
Installing uclibcxx (0.2.4-1) to root...
Downloading http://wl500g-repo.googlecode.com/sv...ibcxx_0.2.4-1_
entware.ipk.
Configuring zlib.
Configuring libffi.
Configuring python-mini.
Configuring python.
Configuring python-django.
Configuring terminfo.
Configuring libbz2.
Configuring libfreetype.
Configuring libjpeg.
Configuring python-imaging
Configuring libjs.
Configuring libreadline.
Configuring libncurses.
Configuring js.
Configuring liblzma.
Configuring libopenssl.
Configuring librtmp.
Configuring libcurl.
Configuring pyopenssl.
Configuring libexpat.
Configuring python-expat.
Configuring libpng.
Configuring libtiff.
Configuring giflib.
Configuring libsqlite3.
Configuring python-sqlite3
Configuring uclibcxx.
Configuring python-curl.
Configuring unrar.
Configuring libgmp.
Configuring python-crypto.
Configuring libleptonica.
Configuring tesseract.
Collected errors:
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/beaker/e
xt/: No space left on device.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/simplejs
on/: No space left on device.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/ordered_dict.py: No su
ch file or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/encoder.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/scanner.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/decoder.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/__init__.py: No such f
ile or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/tool.py: No such file
or directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/:
* wfopen: /opt/share/python/pyload/module/lib/thrift/Thrift.py: No such file or
directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/t
ransport/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TTwisted.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TSocket.py: No s
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TZlibTransport.p
y: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TTransport.py: N
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/__init__.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/THttpClient.py:
* wfopen: /opt/share/python/pyload/module/lib/thrift/TSerialization.py: No such
file or directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/p
rotocol/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TProtocol.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TBase.py: No such
file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TBinaryProtocol.p
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TCompactProtocol.
py: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/__init__.py: No s
* wfopen: /opt/share/python/pyload/module/lib/thrift/TSCons.py: No such file or
directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/s
erver/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TServer.py: No such
file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/THttpServer.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TProcessPoolServer.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TNonblockingServer.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/__init__.py: No suc
* wfopen: /opt/share/python/pyload/module/lib/thrift/__init__.py: No such file
or directory.
* wfopen: /opt/share/python/pyload/module/lib/__init__.py: No space left on dev
ice.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/jinja2/:
* wfopen: /opt/share/python/pyload/module/lib/jinja2/nodes.py: No such file or
directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/bccache.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/filters.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/loaders.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/ext.py: No such file or di
rectory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/constants.py: No such file
or directory.
* wfopen: /opt/share/python/pyload/module/debug.py: No space left on device.
* wfopen: /opt/share/python/pyload/module/InitHomeDir.py: No space left on devi
ce.
* wfopen: /opt/share/python/pyload/.hg_archival.txt: No space left on device.
* wfopen: /opt/share/python/pyload/LICENSE: No space left on device.
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/pyload.list: No space
left on device.
* opkg_install_pkg: Failed to extract data files for pyload. Package debris may
remain!
* opkg_install_cmd: Cannot install package pyload.
Py load not installed,
I don't get why I don't have space left on the device
router@RTAsus:/tmp/mnt/sd# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 24960 24960 0 100% /
tmpfs 119856 2324 117532 2% /tmp
devfs 119856 0 119856 0% /dev
/dev/mtdblock4 6144 412 5732 7% /jffs
/dev/sdb1 976759804 701390496 275369308 72% /tmp/mnt/tera2
/dev/sdc2 7259600 87512 7172088 1% /tmp/mnt/sd
/dev/sda1 976728060 636918124 339809936 65% /tmp/mnt/tera3
My memory seems to be full now, I cant install anything.
router@RTAsus:/tmp/mnt/sd# opkg install nano
Installing nano (2.2.6-1b) to root...
Downloading http://wl500g-repo.googlecode.com/sv...o_2.2.6-1b_ent
ware.ipk.
Collected errors:
* wfopen: //opt/lib/opkg/info/nano.control: No space left on device.
* wfopen: /opt/bin/nano: No space left on device.
* wfopen: /opt/etc/nanorc: No space left on device.
* extract_archive: Cannot make dir /opt/share/nano/: No space left on device.
* wfopen: /opt/share/nano/python.nanorc: No such file or directory.
* wfopen: /opt/share/nano/asm.nanorc: No such file or directory.
* set_flags_from_control: Failed to open //opt/lib/opkg/info/nano.control: No s
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/nano.list: No space le
ft on device.
* opkg_install_pkg: Failed to extract data files for nano. Package debris may r
emain!
* opkg_install_cmd: Cannot install package nano.
Anyone?
Thanks,
Regards!
You have posted this twice within 40 Minutes...
Anyway, can you write to the mounted device where entware ist installed?
Have you checked the Syslog for Error / Warnings?
Rebooted and did a check with Disk Utility?
Sorry and thanks for the help, yes I can read and write on them 3, No I haven't check the syslog for error / warning, I did rebooted, and after that nothing seems to work anymore, transmission crashes, saying that there is no space left when trying to download. No I did not did a check disk, I think It might have something to do with the ram memory, I did created a swap, as it was installing the pyload I was checking its usage, and it went high, left 55mb of its physical and left me 128 of 512mb of the swap! Any sugestions? Regards
Asus RTN66U
JFFS is on
This is what I get
tware.ipk.
ware.ipk.
entware.ipk.
Configuring zlib.
Configuring libffi.
Configuring python.
Configuring libbz2.
Configuring libjs.
Configuring js.
Configuring libpng.
Configuring giflib.
Configuring unrar.
Configuring libgmp.
Collected errors:
Anyone?
The answer appears quite obvious to me. You should have a drive labeled Optware that mounts as /opt created by the generic.sh available for your router hardware type. Then execute opkg from the /opt directory to begin an install of any program available to your system from Entware. This information is documented at Entware Wiki . Personally I think it best for you to make a backup, then reflash the router, restore the backup. In the USB setup add the UUID of the drive labeled Optware to mount on the /opt directory, then the additional units to be installed. Copy the the scrip your system from the Entware blog in the starting script dialog and save it. You may need to adjust the initial sleep command in it up or down to find the timing that will allow the script to run in order to have the Optware labeled drive mounted and available to use. As mentioned above, execute opkg after a you've done 'cd /opt'.
I hope that you find the info on the Wiki matching your router model or CPU type prior to the wipe step I suggest you perform so you can follow the proper steps on the Wiki.
Hope this helps for you
