Installing pyload under Entware Asus Merlin
becamo
Asus RTN66U
Merlin Firmware:3.0.0.4.374.39
1 SD 8gigas card intalled ext2 formated
2 USB disk NTFS Formated
JFFS is on
Installed entware on the sd card
Trying to install pyload
This is what I get
router@RTAsus:/tmp/mnt/sd# opkg install pyload
Installing pyload (0.4.9-1) to root...
Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/pyload_0.4.9-1_en
tware.ipk.
ware.ipk.
Installing uclibcxx (0.2.4-1) to root...
Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/uclibcxx_0.2.4-1_
entware.ipk.
Configuring zlib.
Configuring libffi.
Configuring python-mini.
Configuring python.
Configuring python-django.
Configuring terminfo.
Configuring libbz2.
Configuring libfreetype.
Configuring libjpeg.
Configuring python-imaging
Configuring libjs.
Configuring libreadline.
Configuring libncurses.
Configuring js.
Configuring liblzma.
Configuring libopenssl.
Configuring librtmp.
Configuring libcurl.
Configuring pyopenssl.
Configuring libexpat.
Configuring python-expat.
Configuring libpng.
Configuring libtiff.
Configuring giflib.
Configuring libsqlite3.
Configuring python-sqlite3
Configuring uclibcxx.
Configuring python-curl.
Configuring unrar.
Configuring libgmp.
Configuring python-crypto.
Configuring libleptonica.
Configuring tesseract.
Collected errors:
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/beaker/e
xt/: No space left on device.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/simplejs
on/: No space left on device.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/ordered_dict.py: No su
ch file or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/encoder.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/scanner.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/decoder.py: No such fi
le or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/__init__.py: No such f
ile or directory.
* wfopen: /opt/share/python/pyload/module/lib/simplejson/tool.py: No such file
or directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/:
* wfopen: /opt/share/python/pyload/module/lib/thrift/Thrift.py: No such file or
directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/t
ransport/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TTwisted.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TSocket.py: No s
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TZlibTransport.p
y: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/TTransport.py: N
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/__init__.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/transport/THttpClient.py:
* wfopen: /opt/share/python/pyload/module/lib/thrift/TSerialization.py: No such
file or directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/p
rotocol/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TProtocol.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TBase.py: No such
file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TBinaryProtocol.p
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/TCompactProtocol.
py: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/protocol/__init__.py: No s
* wfopen: /opt/share/python/pyload/module/lib/thrift/TSCons.py: No such file or
directory.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/thrift/s
erver/: No such file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TServer.py: No such
file or directory.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/THttpServer.py: No
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TProcessPoolServer.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/TNonblockingServer.
* wfopen: /opt/share/python/pyload/module/lib/thrift/server/__init__.py: No suc
* wfopen: /opt/share/python/pyload/module/lib/thrift/__init__.py: No such file
or directory.
* wfopen: /opt/share/python/pyload/module/lib/__init__.py: No space left on dev
ice.
* extract_archive: Cannot make dir /opt/share/python/pyload/module/lib/jinja2/:
* wfopen: /opt/share/python/pyload/module/lib/jinja2/nodes.py: No such file or
directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/bccache.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/filters.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/loaders.py: No such file o
r directory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/ext.py: No such file or di
rectory.
* wfopen: /opt/share/python/pyload/module/lib/jinja2/constants.py: No such file
or directory.
* wfopen: /opt/share/python/pyload/module/debug.py: No space left on device.
* wfopen: /opt/share/python/pyload/module/InitHomeDir.py: No space left on devi
ce.
* wfopen: /opt/share/python/pyload/.hg_archival.txt: No space left on device.
* wfopen: /opt/share/python/pyload/LICENSE: No space left on device.
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/pyload.list: No space
left on device.
* opkg_install_pkg: Failed to extract data files for pyload. Package debris may
remain!
* opkg_install_cmd: Cannot install package pyload.
Py load not installed,
I don't get why I don't have space left on the device
router@RTAsus:/tmp/mnt/sd# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 24960 24960 0 100% /
tmpfs 119856 2324 117532 2% /tmp
devfs 119856 0 119856 0% /dev
/dev/mtdblock4 6144 412 5732 7% /jffs
/dev/sdb1 976759804 701390496 275369308 72% /tmp/mnt/tera2
/dev/sdc2 7259600 87512 7172088 1% /tmp/mnt/sd
/dev/sda1 976728060 636918124 339809936 65% /tmp/mnt/tera3
My memory seems to be full now, I cant install anything.
router@RTAsus:/tmp/mnt/sd# opkg install nano
Installing nano (2.2.6-1b) to root...
Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/nano_2.2.6-1b_ent
ware.ipk.
Collected errors:
* wfopen: //opt/lib/opkg/info/nano.control: No space left on device.
* wfopen: /opt/bin/nano: No space left on device.
* wfopen: /opt/etc/nanorc: No space left on device.
* extract_archive: Cannot make dir /opt/share/nano/: No space left on device.
* wfopen: /opt/share/nano/python.nanorc: No such file or directory.
* wfopen: /opt/share/nano/asm.nanorc: No such file or directory.
* set_flags_from_control: Failed to open //opt/lib/opkg/info/nano.control: No s
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/nano.list: No space le
ft on device.
* opkg_install_pkg: Failed to extract data files for nano. Package debris may r
emain!
* opkg_install_cmd: Cannot install package nano.
Anyone?
Thanks,
Regards!
