A list of available commands would be helpful as well.
Are there any instructions you know of that will list the syntax to be used and what commands the custom configuration window will accept? for example: help does nothing. So I think I need at least 1 or 2 more documents to understand fully how to use this.
/etc/openvpn/server1/config.ovpn
Since im nosy, what do you have in your connect/ disconnect scripts?All of the Server/Client directives are described here:
Usually the 2.4 page is for the most recent firmware although the 2.3 page may still be relevant:
https://openvpn.net/index.php/open-source/documentation/manuals.html
To use them in the custom window on ASUS routers simply remove the '--' prefix
They will then appear at the end of the appropriate active OpenVPN instance e.g. Server 1.
Code:/etc/openvpn/server1/config.ovpn
# Custom CCD directives for single common name 'client' user SGS5 (see /jffs/scripts/VPNClientConnect.sh)
# Assign static I/P xxx.xxx.xxx.22 (Normally assume defaults xxx.xxx.xxx=10.8.0 for VPN Server 1, and xxx.xxx.xxx=10.16.0 for VPN Server 2)
# NOTE: 'staticip' ('staticipv6') is NOT an official OpenVPN directive, but it is an easy to remember psuedo command short-cut!
staticip 22
# User SGS5 will pass-through the router direct via VPN Client 1 (New York) aka ovpnc1
# NOTE: 'passthru' is also NOT an official OpenVPN directive
passthru 1
Would appreciate any input. Is this management interface feature used on a Asus router?
...access the "management interface" as explained in the openvpn documentation because the server is on the router - For that to have a chance of working I would have to have something like Dnsmasq so I can make the router's localhost available to the LAN.
# Custom Configuration
management localhost 7505
admin@RT-AC68U:/jffs/scripts# telnet localhost 7505
>INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
help
Management Interface for OpenVPN 2.4.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 12 2017
Commands:
auth-retry t : Auth failure retry mode (none,interact,nointeract).
bytecount n : Show bytes in/out, update every n secs (0=off).
echo [on|off] [N|all] : Like log, but only show messages in echo buffer.
exit|quit : Close management session.
forget-passwords : Forget passwords entered so far.
help : Print this message.
hold [on|off|release] : Set/show hold flag to on/off state, or
release current hold and start tunnel.
kill cn : Kill the client instance(s) having common name cn.
kill IP:port : Kill the client instance connecting from IP:port.
load-stats : Show global server load stats.
log [on|off] [N|all] : Turn on/off realtime log display
+ show last N lines or 'all' for entire history.
mute [n] : Set log mute level to n, or show level if n is absent.
needok type action : Enter confirmation for NEED-OK request of 'type',
where action = 'ok' or 'cancel'.
needstr type action : Enter confirmation for NEED-STR request of 'type',
where action is reply string.
net : (Windows only) Show network info and routing table.
password type p : Enter password p for a queried OpenVPN password.
remote type [host port] : Override remote directive, type=ACCEPT|MOD|SKIP.
proxy type [host port flags] : Enter dynamic proxy server info.
pid : Show process ID of the current OpenVPN process.
client-auth CID KID : Authenticate client-id/key-id CID/KID (MULTILINE)
client-auth-nt CID KID : Authenticate client-id/key-id CID/KID
client-deny CID KID R [CR] : Deny auth client-id/key-id CID/KID with log reason
text R and optional client reason text CR
client-kill CID [M] : Kill client instance CID with message M (def=RESTART)
env-filter [level] : Set env-var filter level
client-pf CID : Define packet filter for client CID (MULTILINE)
rsa-sig : Enter an RSA signature in response to >RSA_SIGN challenge
Enter signature base64 on subsequent lines followed by END
certificate : Enter a client certificate in response to >NEED-CERT challenge
Enter certificate base64 on subsequent lines followed by END
signal s : Send signal s to daemon,
s = SIGHUP|SIGTERM|SIGUSR1|SIGUSR2.
state [on|off] [N|all] : Like log, but show state history.
status [n] : Show current daemon status info using format #n.
test n : Produce n lines of output for testing/debugging.
username type u : Enter username u for a queried OpenVPN username.
verb [n] : Set log verbosity level to n, or show if n is absent.
version : Show current version number.
END
OOh thank you! Definitely given me some pointers. I like the passthru concept, I shall dig into the OVPN man again (unless it's as simple as redirect-gateway def1 and then use OVPN client policy routing for the required IP?)The 'client-connect' script allows a config file of custom OpenVPN directives to be applied on a Username basis
e.g. My phone 'SGS5' when it connects to either of the Openvpn Servers causes the script to read the appropriate server instance custom config file:
e.g. OpenVPN Server 1
/jffs/configs/openvpn/ccd1/client_SGS5
Code:# Custom CCD directives for single common name 'client' user SGS5 (see /jffs/scripts/VPNClientConnect.sh) # Assign static I/P xxx.xxx.xxx.22 (Normally assume defaults xxx.xxx.xxx=10.8.0 for VPN Server 1, and xxx.xxx.xxx=10.16.0 for VPN Server 2) # NOTE: 'staticip' ('staticipv6') is NOT an official OpenVPN directive, but it is an easy to remember psuedo command short-cut! staticip 22 # User SGS5 will pass-through the router direct via VPN Client 1 (New York) aka ovpnc1 # NOTE: 'passthru' is also NOT an official OpenVPN directive passthru 1
Effectively (if you know the appropriate OpenVPN syntax) any valid OpenVPN directive can be used in the file or as in the example above, simple custom pseudo commands are replaced by the appropriate OpenVPN directives.
e.g. the IPv4 'staticip' directive will determine the appropriate VPN Server instance subnet prefix (as specified in the GUI) and force the phone to always be assigned the requested I/P address.
Furthermore, the script emails details of the new client connection, and can (if so desired) also reject the client connection request...even if the Username/password combo is still valid!
v3.01 was posted here:
https://www.snbforums.com/threads/how-to-set-a-static-ip-to-openvpn-tun-clients.37983/#post-315194
The 'client-disconnect' script removes any custom configuration (routes etc.) and also generates another statistics email which now includes the duration of the client connection together with the amount of data transferred.
Don't suppose there's a copy of the disconnect script you wrote? I'm trying to brush up on my shell scripting!
What? dnsmasq is already enabled by default on the router.
So once...
END[/CODE]
Thanks, found what I'd like to do, good stuff.The 'client-disconnect' script simply consists of a couple of RPDB deletes and the remainder is just the email portion cloned from the 'client-connect' script, albeit with a more comprehensive list (15?) of OpenVPN environment variables, so I seriously doubt it would in any way supplement your current shell scripting skills.
So once the directive is enabled on the router
Code:# Custom Configuration management localhost 7505
then it can be accessed via Telnet once you are connected to the router command line (e.g. telnet router.asus.com assuming Telnet/SSH access is enabled in the router GUI)
Code:admin@RT-AC68U:/jffs/scripts# telnet localhost 7505 >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info help Management Interface for OpenVPN 2.4.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 12 2017 Commands: auth-retry t : Auth failure retry mode (none,interact,nointeract). bytecount n : Show bytes in/out, update every n secs (0=off). echo [on|off] [N|all] : Like log, but only show messages in echo buffer. exit|quit : Close management session. forget-passwords : Forget passwords entered so far. help : Print this message. hold [on|off|release] : Set/show hold flag to on/off state, or release current hold and start tunnel. kill cn : Kill the client instance(s) having common name cn. kill IP:port : Kill the client instance connecting from IP:port. load-stats : Show global server load stats. log [on|off] [N|all] : Turn on/off realtime log display + show last N lines or 'all' for entire history. mute [n] : Set log mute level to n, or show level if n is absent. needok type action : Enter confirmation for NEED-OK request of 'type', where action = 'ok' or 'cancel'. needstr type action : Enter confirmation for NEED-STR request of 'type', where action is reply string. net : (Windows only) Show network info and routing table. password type p : Enter password p for a queried OpenVPN password. remote type [host port] : Override remote directive, type=ACCEPT|MOD|SKIP. proxy type [host port flags] : Enter dynamic proxy server info. pid : Show process ID of the current OpenVPN process. client-auth CID KID : Authenticate client-id/key-id CID/KID (MULTILINE) client-auth-nt CID KID : Authenticate client-id/key-id CID/KID client-deny CID KID R [CR] : Deny auth client-id/key-id CID/KID with log reason text R and optional client reason text CR client-kill CID [M] : Kill client instance CID with message M (def=RESTART) env-filter [level] : Set env-var filter level client-pf CID : Define packet filter for client CID (MULTILINE) rsa-sig : Enter an RSA signature in response to >RSA_SIGN challenge Enter signature base64 on subsequent lines followed by END certificate : Enter a client certificate in response to >NEED-CERT challenge Enter certificate base64 on subsequent lines followed by END signal s : Send signal s to daemon, s = SIGHUP|SIGTERM|SIGUSR1|SIGUSR2. state [on|off] [N|all] : Like log, but show state history. status [n] : Show current daemon status info using format #n. test n : Produce n lines of output for testing/debugging. username type u : Enter username u for a queried OpenVPN username. verb [n] : Set log verbosity level to n, or show if n is absent. version : Show current version number. END
Sadly you don't win the prize, I think someone resurrected one of my posts that was three years old!, but thank you anyway.I realize that this is a real old thread, but adding "management localhost 7505" to the custom configuration worked like a charm.
Welcome To SNBForums
