GemeenAapje
Firstly I love the site, it's provided me with great help in the past... especially the throughput tests!
I'm now hoping you can help me with an issue I have.
At home I have a Linksys WRT610N (V1). My work have given my a new Dell Latitude E6400 laptop which has an Intel 5300AGN wifi card built in.
Now, for the life of me I cannot get the 2 devices to communicate on Wireless N. A/B/G are all fine, on either 2.4ghz or 5ghz levels. As soon as I enabled "Wireless N Only" it completely fails. If I enable "Mixed" then it just uses Wireless G.
It's driving me absolutely insane! I'm an IT Professional so I know what I'm doing, but no configuration seems to be able to get this running as it should be. All drivers and firmware are updated.
Please can you give me some suggestions?
Current settings... Both 2.4 and 5ghz antenna enabled, both mixed, all options set to Auto or Default. Security set to WPA2.
Many thanks in advanced
Matt
Matt
