L
lazor
Guest
Since I've been dealing over the phone with Intel tech support since Monday, it would be really nice if I can cross-reference things with anyone here who might be familiar with this...
I bought an Intel SS4200-E (software version that comes with the EMC DOM). It has 4 brand new Western Digital 500gig drives installed. I connect it to the router, plug in the power and turn it on. It powers up, the hard drive lights go solid, and the power button blinks. That's it. It never registers an IP via DHCP on my router and the Intel Management software can't find the device.
The tech guys at Intel think the device is trying to boot off the installed hard drives instead of the installed DOM. They sent a replacement, but it does the same thing.
I'm supposed to be able to plug a serial header (DH10 to DB9) into the serial debug port on the ss4200's motherboard.... I did that. I then connected to com1 on a XP machine (tried a straight serial and a null modem cable) and set the port to 115200, 8n1, no flow control. Garbage is all that ever displays.
They tell me I should be able to open a terminal window through the serial port to see the bootup screen and management console. From there, I'm supposed to be able to change the BIOS to boot from the DOM instead of the hard drives.
I'm stuck since I can't get into the management console via serial connection. I checked the pinout on the motherboard's port and I don't think it's definitely not the same pinout used by the serial port on my desktop motherboard. My desktop has a pinout of:
1 DCD
2 RXD
3 TXD
4 DTR
5 GND
6 DSR
7 RTS
8 CTS
9 RI
The port on the SS4200 has a pinout of:
1 DCD
2 DSR
3 RX
4 RTS
5 TX
6 CTS
7 DTR
8 RI
9 GND
I'm just using a standard RS232 Serial MB Header to go from DH10 to DB9 on each motherboard and then I've tried to connect between the two with a straight through as well as a null modem cable - no luck.
Is there a way for me to get the serial terminal window working? I've tried using two computers. I've tried different serial cables. I tried different network cables. I even tried an old router to see if that would make the ss4200 happy. Oh, and I tried using 2 drives and 0 drives in the system to see if it would come online - no luck.
Any ideas? Are my guesses about the pinout mismatch correct?
Thanks,
-Ed
1 DCD
2 RXD
3 TXD
4 DTR
5 GND
6 DSR
7 RTS
8 CTS
9 RI
1 DCD
2 DSR
3 RX
4 RTS
5 TX
6 CTS
7 DTR
8 RI
9 GND
Thanks,
-Ed
