Thanks for the article link. I'm not familiar with William Van Winkle. But it looks like he tried to do a pretty thorough job in testing. A few points:
He used a vendor-supplied tool for most of his data-taking. I would never do that, since you don't know what sort of optimizations could be baked into it.
He included IxChariot TCP/IP based tests, but that's not how he did most of his testing. Of course, IxChariot can test using UDP or RDP or other protocols and also has test files that emulate video streaming.
Second point is that UDP isn't always used for video streaming. It depends on how the player connects to the source file. TCP/IP is actually more resistant to packet loss than UDP, as I showed in
Video Streaming Need To Know: Part 1- Encoding, Bit Rates and Errors.
From the streaming tests that I have done, I've found that you're actually more likely to be using TCP/IP when playing a file from a NAS using a networked media player.
The AP he tested is an enterprise AP, and as he pointed out, not designed for media streaming per se. You would be more likely to use one (or a pair) of Ruckus' MediaFlex products (MediaFlex 7811 multimedia access point (AP) and the Ruckus MediaFlex 7111 multimedia Wi-Fi adapter).
From the way I see the industry going, it's going to take a dedicated product to handle good HD streaming over any distance. Consumer wireless manufacturers are optimizing products for low cost and high speed, often at the cost of range and throughput stability. And 5 GHz range remains poor compared to 2.4 GHz.
I actually wrote the Tom's Guide
MIMO Router Face-Off (now attributed to "TG Publishing Team"). Ruckus was not at all happy about having their MF2900 and MF2501 compared to other MIMO products (and that they didn't do that well), since they said the pair was designed for video streaming, not for general purpose wireless networking. I haven't heard much of anything from them since then
The article is also correct that Ruckus didn't like life in the retail networking space. I think the MediaFlex 7111/7811 pair is primarily used by service providers now.
I don't think they are interested in retail business, but I'll ping Ruckus to see if they would be interested in providing the 5GHz MediaFlex pair for a video streaming test.
