freeridr05
Hey there - thanks in advance for reading this and any help.
Setup: I have an ASUS AX86S running Skynet, Diversion, and Unbound.
Symptom: I've been experiencing intermittent internet connectivity loss - each bout lasts maybe a second and is primarily noticed when on video calls. My internet connection is otherwise super stable (fiber).
Maybe solution: I've disabled Skynet and it seems to be helping, but it hasn't been long enough to know for sure if this was the fix.
Question: Is there any reason to believe Skynet, Diversion, or Unbound would be causing these issues? If so, is there any configuration change I should look into making to continue using e.g. Skynet without causing these issues?
Thank you!
Thank you!
