Hi All,
I'm trying to troubleshoot an issue that has seemingly cropped up lately where my iPhone 16 Pro Max and iPad M4 Pro on iOS 18 stop responding to the Wi-Fi network for up to 30 seconds. It will eventually kick in if I let it sit.
Router: GT-AXE16000 with Asus-Merlin 3004.388.8_4
Network: iOS devices are connected to the 6Ghz and 5Ghz, they roam back and forth using Smart Connect based on signal strength (this has seemingly worked well).
iOS: Private Wi-Fi Address is off
When the issue occurs, the following shows up the in the router system log:
Feb 17 16:14:16 wlceventd: wlceventd_proc_event(695): eth9: ReAssoc <Mac Address>, status: Successful (0), rssi:-60
Feb 17 16:14:58 wlceventd: wlceventd_proc_event(645): eth8: Deauth_ind <Mac Address>, status: 0, reason: Disassociated due to inactivity (4), rssi:-54
Feb 17 17:03:06 wlceventd: wlceventd_proc_event(685): eth8: Auth <Mac Address>, status: Successful (0), rssi:0
Feb 17 17:03:06 wlceventd: wlceventd_proc_event(695): eth8: ReAssoc <Mac Address>, status: Successful (0), rssi:-70
Feb 17 17:03:28 wlceventd: wlceventd_proc_event(645): eth9: Deauth_ind <Mac Address>, status: 0, reason: Disassociated due to inactivity (4), rssi:-60
Feb 17 18:40:36 wlceventd: wlceventd_proc_event(695): eth9: ReAssoc <Mac Address>, status: Successful (0), rssi:-70
Feb 17 18:41:12 wlceventd: wlceventd_proc_event(645): eth8: Deauth_ind <Mac Address>, status: 0, reason: Disassociated due to inactivity (4), rssi:-64
Feb 17 20:01:58 wlceventd: wlceventd_proc_event(685): eth8: Auth <Mac Address>, status: Successful (0), rssi:0
Feb 17 20:01:58 wlceventd: wlceventd_proc_event(695): eth8: ReAssoc <Mac Address>, status: Successful (0), rssi:-86
Feb 17 20:02:08 wlceventd: wlceventd_proc_event(645): eth9: Deauth_ind <Mac Address>, status: 0, reason: Disassociated due to inactivity (4), rssi:-83
Feb 17 20:04:55 wlceventd: wlceventd_proc_event(662): eth8: Disassoc <Mac Address>, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 17 20:04:55 wlceventd: wlceventd_proc_event(645): eth8: Deauth_ind <Mac Address>, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 17 20:09:45 wlceventd: wlceventd_proc_event(685): eth8: Auth <Mac Address>, status: Successful (0), rssi:0
Feb 17 20:09:45 wlceventd: wlceventd_proc_event(722): eth8: Assoc <Mac Address>, status: Successful (0), rssi:-86
Feb 17 20:58:33 wlceventd: wlceventd_proc_event(695): eth9: ReAssoc <Mac Address>, status: Successful (0), rssi:-60
Feb 17 20:59:02 wlceventd: wlceventd_proc_event(645): eth8: Deauth_ind <Mac Address>, status: 0, reason: Disassociated due to inactivity (4), rssi:-48
I changed Wi-Fi DTIM Interval from 1 to 3 and disabled Universal Beamforming based on some threads out there, but no luck with fixing the issue.
Perhaps it's Smart Connect rules, but I don't recall this happening before or at least it wasn't this noticeable. The main goal with this was to keep the devices on 6Ghz, as without it they would keep falling back to 5Ghz and never switch back to 6Ghz.
If anyone else is running into this same issue or has some ideas, thanks in advance.
