iPhone 15 USB Tethering and trust issues
bortek
Hi
I am trying to setup iPhone 15 as a USB tethering modem on AC86U using latest AsusWRT-Merlin fw. All works well, except that I need to manually press Trust popup every time I reconnect phone or most importantly every time I reboot the router. Idea was to use iPhone as a 5G modem and if I need to press Trust every time when router reboot (that is daily) then this just wont work.
I have found this script that is supposed to solve it but it does not make a trick
Problem is that the SystemBUI and HostID are changing every time I reconnect or reboot the device. And even if I try to replace the files under /var/lib/lockdown directory with the ones from previous session it does not bite it. Even after replacing SystemUID taken from the SystemConfiguration.plist file.
So question is is it even possible to establish that permament trust between phone and router that is peremanet between reboots?
Hi
Have you looked at Settings >> General >> About >> Certificate Trust Settings?
Now I have looked and there are versions numbers for certs and 2 Root certs which are trusted. I connected a phone to get a "Trust" pop-up, trusted then went and looked again in About but there was not any cert that I could trust.
