IPSec question
ryarber
As a newbie here and at the risk of inflaming the ire of the flame merchants that abound on this board I ask a question...
As a business owner, I want a router that will allow me to access my cisco routers via an IPSec client that will maintain a tunnel between my private home network and my work network. As a parent, I want a full featured consumer router with micro control of my children's internet access.
As I understand IPSec clients, the principle reason that consumer grade routers haven't done IPSec client duties in the past is that they aren't capable of performing the encryption/deencryption duties necessary of a true IPSec client. With the capabilities of the new routers such as the RT-AC68U from ASUS, these consumer grade routers have dramatically increased their processing capabilities. Is it in the foreseeable future that these devices may take on the IPSec client role that the business class devices have done in the past?
If you load optware, and load strongSwan you should be able to run IPsec no problem on the Asus RT-AC68U with Merlin's firmware as I believe he has had this since 374.34...I will load it up today, and see if I can run IPSec back to my office but I am pretty sure it will work just fine.
A question I have is why not use OpenVPN -- I feel it is a great mix of reliability and performance.
https://www.ivpn.net/pptp-vs-l2tp-vs-openvpn
Gives a nice overview. I am running openvpn with no issues with two of my AC68U's -- merlin's firmware really has a nice mix of performance and features...
I'm not knowledgeable about these issues and I was told IPSec is the way to go as far as maintaining a static tunnel. I'll get my network guy to look at OpenVPN to see if it is a viable alternative.
Thanks.
I include the necessary kernel level support for IPSec, but you will have to install and configure Strongswan to handle the userspace part.
I have never looked at IPSec under Linux, so I have no idea what type of configuration is involved.
It looks like OpenVPN will do everything IPSec will do. But my Cisco firewall doesn't do OpenVPN, does it?
I talked to my IT guy about it and he isn't sure how to make it work on the front end.
If the goal is to connect back to your home network while at work, install the OpenVPN client on your work computer. The Asus router at home will act as your server.
No. The goal is to connect to work from home. To a Cisco ASA appliance.
Then you would have to either run an OpenVPN server at work, or have your client at work automatically connect to your server to have a permanent tunnel in place.
Cisco does not support SSL VPNs on their devices, only IPSec and their own cooked variant.
It sounds like you want to create a LAN to LAN connection between your home and work networks. If this is the case then I'd have to ask you why? Do you really need to have multiple hosts permanently connected to your work network with all of the security implications that has? If you're talking about 1 or 2 PC's why not just use the Cisco VPN client?
Because I use Macs at home. Last time I checked, Cisco didn't have a Mac VPN client. After your suggestion, I looked and apparently they have one now. That'd probably be a better option for me. Thanks.
I had used a small biz router at home in the past and had a static tunnel in place for a couple years. But I wanted to manage my kids' access more as well as have a separate guest access, so I decided to go with the asus.
I guess I was just stuck in my old way of thinking and had forgotten about the simple approach. I appreciate you guys' help.
Actually you don't need a client. You can use the built-in IPSEC support in recent Mac OSX releases. I configured a customer's Mac a few months ago so she could connect back to their Cisco VPN at work.
That reminds me, I was totally surprised to see that the Apple iPhone & iPad also have built in support for connecting to my work's Cisco VPN.
