Hi all;
I have Asus Ax86u Pro router with the latest Merlin version istalled. I set up IpSec Vpn Server on the router. What I am trying to do is assign IPs to Vpn clients from the routers DHCP pool, not from the IP range 10.10.10.1-254 that is default on the router.
I limited router's DHCP server IP pool from 192.168.3.2 to 192.168.3.244. I want to use the remaining 10 IP numbers for Vpn clients but IPSec Server advanced settings does not allow entering an IP subset. Any way to specify IPsec Vpn Server client IP range from 192.169.3.245 o 192.168.3.254?
Thanks.
Thanks.
