ipset Bogon filtering
  • Thread starter Thread starter krabs
  • Start date Start date
K
krabs
Guest
#!/bin/sh
# fullbogons-ipv4
# Based on BoneKracker and Ryzhov_Al coded scripts.
# Entware version of wget needed for Time-Stamping.
# Purpose: Periodically update an ipset used in a running firewall to block
# bogons. Bogons are addresses that nobody should be using on the public
# Internet because they are either private, not to be assigned, or have
# not yet been assigned.
# Notes: Call this from crontab. Feed updated every 4 hours.
# Loading ipset modules
lsmod | grep "ipt_set" > /dev/null 2>&1 || \
for module in ip_set ip_set_nethash ipt_set
do
    insmod $module
done
IPSET_TARGET="http://www.team-cymru.org/Services/Bogons/fullbogons-ipv4.txt"
IPSET_LISTS_DIR=/tmp/mnt/data/ipset_lists // change directory to yours
IPSET_DATA_FILE="${IPSET_LISTS_DIR}/fullbogons-ipv4.txt"
# Preparing folder to cache downloaded files
[ -d "$IPSET_LISTS_DIR" ] || mkdir -p $IPSET_LISTS_DIR
# Function to get modification time of the file in log-friendly format
get_timestamp() {
    date -r "$1" +'%m/%d %R'
# File modification time on server is preserved during wget download
[ -w "$IPSET_DATA_FILE" ] && old_timestamp=$(get_timestamp "$IPSET_DATA_FILE")
# Fetch file only if newer than the version we already have
/opt/bin/wget -qNP ${IPSET_LISTS_DIR} ${IPSET_TARGET} 2>&1 \
 | logger -t ipset -p cron.err
# Report exit status to "System Log" if download not successful or continue script
if [ $? -ne 0 ]
then
    logger -t ipset -p cron.err "Error, exit script;"
    exit 1
fi
# Compare timestamps because wget returns success even if no newer file
if [ "${timestamp}" != "${old_timestamp}" ]
then
    # Block traffic from fullbogons-ipv4
    if [ "$(ipset --swap FullBogons FullBogons 2>&1 | grep 'Unknown set')" != "" ]
    then
        ipset -N FullBogons nethash
        sed -ri '/^[#< \t]|^$/d' $IPSET_DATA_FILE
        for IP in $(cat $IPSET_DATA_FILE)
        do
            ipset -A FullBogons $IP
        done
    fi
    iptables-save | grep FullBogons > /dev/null 2>&1 || iptables -I INPUT -i eth0 -m set --set FullBogons src -j DROP
else
    logger -t ipset -p cron.err "wget: Server file no newer than local file -- not retrieving, exit script;"
fi
add a cronjob to /jffs/scripts/services-start to run it every 4 hours
update timings file are as follows
# 00:48 - 00:50
# 04:48 - 04:50
# 08:48 - 08:50
# 12:48 - 12:50
# 16:48 - 16:50
# 20:48 - 20:50
/usr/sbin/cru a fullbogons      "52 */4 * * *   sh /<script location>/fullbogons.sh"
