Iptables block access for IP Cameras with exceptions
NomisGnos
Hello long time lurker first time poster. Community here is awesome!
I have an ASUS 3100 wireless router and about 4 IP Cameras. On my old router it was easy to block outgoing traffic so that I can make sure the cameras weren't "calling home". I want to do the same thing with this router so I decided first I use the port forwarding tool and then I started looking up IPTABLES.
My goal:
  1. By default block outgoing and incoming traffic for 192.168.1.0/29
  2. Exception: I want to open 120:130 BUT for only a handful of trusted IPs (work or a friends house). Lets say those IPs are 150.150.150.150 and 250.250.250.0/24 (I use a browser to access these ports, not that probably matters anyways) so if I wanted to access CAMERA #2 it would be DDNS.dns.com:121
  3. Exception: The cameras send out emails via SMTPS (port 465) so I want to open that up so that it can send out the emails.
  4. Don't want to block INPUTS/OUTPUTS since I have some IoT stuff that communicate somewhere else , so I don't want to change default policy to block that. Unless I am misunderstanding how that works.
I flashed the router with the latest Asuswrt-Merlin and turned on JFFS custom scripts. I created a file under
/jffs/scripts/
called
firewall-start
. I edited the file starting with shebang and added some rules (will get back to this later). I used
service restart_firewall
. The problem I am getting into is that I am not getting the appropriate results and it is very possible that I am writing the rules wrong and/or maybe the order.
I tried iptables forward, I tried iptables INPUT & OUTPUT, and I tried a combination of "INSERT" / "APPEND" and for some odd reason it will either BLOCK everything or leave it OPEN completely. It never follows my ultimate goal. I am sure it has to do with some order or default rules for FORWARD or INPUT or OUTPUT but I just cant figure it out.
I need some experts to help me out. Here is my existing iptable as of right now:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
DROP       icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
DROP       all  --  anywhere             anywhere             state INVALID
PTCSRVWAN  all  --  anywhere             anywhere
PTCSRVLAN  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             state NEW
OVPN       all  --  anywhere             anywhere             state NEW
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
INPUT_ICMP  icmp --  anywhere             anywhere
Chain FORWARD (policy DROP)
other2wan  all  --  anywhere             anywhere
NSFW       all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain ACCESS_RESTRICTION (0 references)
Chain FUPNP (0 references)
Chain INPUT_ICMP (1 references)
RETURN     icmp --  anywhere             anywhere             icmp echo-request
RETURN     icmp --  anywhere             anywhere             icmp timestamp-request
ACCEPT     icmp --  anywhere             anywhere
Chain NSFW (1 references)
Chain OVPN (2 references)
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (0 references)
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST
RETURN     icmp --  anywhere             anywhere             icmp echo-request limit: avg 1/sec burst 5
RETURN     all  --  anywhere             anywhere
Chain default_block (0 references)
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
Chain other2wan (1 references)
Thanks in advance!
