iptables/OpenVPN not applying rule
  • Thread starter Thread starter Deleted member 19827
  • Start date Start date
D
Guest
Hi there
I would like to forward port 53 to 1194 (UDP/OpenVPN) with iptables. I applied these same steps in an earlier version of Asuswrt-Merlin and it worked without any problems. After upgrading to a recent version it stopped to work. The iptable rule doesn't seem to be applied.
____________________________________
My configuration:
Device: Asus RT-AC66U
Firmware: 376.45 (Asuswrt-Merlin)
OpenVPN: Listening on port 1194 UDP, works
Autostart script install steps:
cd /jffs/scripts/
vi firewall-start
<INSERTED>
#!/bin/sh
iptables -t nat -A PREROUTING -p udp -d $(nvram get wan0_ipaddr) -i $(nvram get wan0_ifname) --dport 53 -j REDIRECT --to-port 1194
</INSERTED>
Note: $(nvram get wan0_ifname) = eth0
chmod a+rx /jffs/scripts/*
. firewall-start
After running the script or the command manually will not return any error message.
iptables config after running the command:
admin@RT-AC66U:/tmp/home/root# iptables --list
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere
ACCEPT udp -- anywhere anywhere udp dpt:1194
DROP all -- anywhere anywhere state INVALID
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
Chain FORWARD (policy DROP)
DROP icmp -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain logaccept (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `ACCEPT '
Chain logdrop (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `DROP '
Any help is highly appreciated.
Best regards
DR_HAMMER
Rules aimed at the NAT chain should go in nat-start rather than firewall-start.
And to list the nat rules, you have to specify that in iptables list command
iptables -t nat -L
Thanks for the quick answers.
I renamed my script to "nat-start" as proposed. But after executing the command/script my rule still doesn't seem to be applied?
admin@RT-AC66U:/jffs/scripts# iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
VSERVER all -- anywhere xyz.com
REDIRECT udp -- anywhere xyz.com udp dpt:domain redir ports 1194
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- !xyz.com anywhere
MASQUERADE all -- anywhere anywhere MARK match 0xd001
Chain DNSFILTER (0 references)
Chain LOCALSRV (0 references)
Chain VSERVER (1 references)
VUPNP all -- anywhere anywhere
Chain VUPNP (1 references)
DNAT tcp -- anywhere anywhere tcp dpt:28940 to:192.168.255.4:32400
I upgraded to Merlin version 376.47 in the meantime.
Any suggestions? Have there been any changes in iptables recently?
Please try this just to double check where we are at.....
reboot the router
enter the iptables routing command via command line
enter 'iptables -t nat -S'
the last command will print the rules in the same format as they are entered and it is sometimes easier to see what is going on.
#!/bin/sh
Your rule has been appended twice in the above PREROUTING table, so the script nat-start is working.
You might want to use the following command to view the nat table so that it does not try to resolve IP addresses.
iptables -L -n -t nat
Sent from my Samsung S3 (GT-i9300) on Sammy JB 4.3 (NB6) powered by Boeffla kernel via Tapatalk
admin@RT-AC66U:/tmp/home/root# iptables -t nat -S
iptables v1.3.8: Unknown arg `-S'
Try `iptables -h' or 'iptables --help' for more information.
admin@RT-AC66U:/tmp/home/root# iptables -L -n -t nat
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1194
VSERVER all -- 0.0.0.0/0 w.x.y.z
REDIRECT udp -- 0.0.0.0/0 w.x.y.z udp dpt:53 redir ports 1194
MASQUERADE all -- !w.x.y.z 0.0.0.0/0
MASQUERADE all -- 0.0.0.0/0 0.0.0.0/0 MARK match 0xd001
VUPNP all -- 0.0.0.0/0 0.0.0.0/0
DNAT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:21021 to:w.x.y.z:21021
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:21021 to:w.x.y.z:21021
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:6881 to:w.x.y.z:6881
DNAT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:6881 to:w.x.y.z:6881
The first command couldn't be recognized but the second one worked thanks a lot. It helped me for further investigation.
After upgrading to version 376.47 and a configuration reset it works now.
Thanks a lot for all the help! :)
Sorry about that....iptables is one of the components where there are different releases on the various router models (as I've discovered recently). -S is only supported on the AC56/AC68, so nothing wrong with your setup in case you were wondering.
