Hi!
I recwntly switched from a Deco M4 (2pcs) to an ROG GT AX-6000 and TUF ax-4200 combination and this is where the problem starts. My ISP modem is connectod to the ROG 6000 and that is connected to the TUF 4200 via ethernet cable enabling wired backhaul and aimesh. My isp box is connected to the TUF 4200, but the TV is dead silent, there is nothing visible (everything else is working fine on the tv, so I have internet on it).
What I've tried:
Enable IPTV for the rog 6000 on lan4 where the tuf ax4200 is connected (the isp set top box is also connected to lan4 on the tuf ax4200). When I do this the aimesh is no longer visible and I can only see the rog 6000 (the tuf ax 4200 is now not shown connected) and also no effect on the TV. When i disable this the aimesh connects once again.
Does someany has an idea how to fix this or if it is even possible?
What I've tried:
