eclp
One of the two settings, either "DNS Rebind protection" and/or "DNSSEC support" on the WAN settings tab breaks my IPv6 connection and also DNSSEC.
It happens even after a complete factory reset (L&LD) of my AX88U, either with 384.15 or 384.16_a2 with minimal configuration. Interestingly and although I have completely disabled DNSSEC rootcanary.org shows me correct test results and also here, dnssec.vs.uni-due.de as if I had activated DNSSEC in the router.
I am using Cloudflare-DOT (IPv4 and IPv6) and never had the slightest problem (since implementation in the firmware). Could it be that the Cloudflare itself has changed something? On the test page internet.nl I'm getting strange results independent of the two settings. The two cloudflare test pages 1.1.1.1/help and cloudflare.com/ssl/encrypted-sni only give correct results if "DNS Rebind protection" and/or "DNSSEC support" are deactivated.
All very strange. Any help is welcome!
