IPv6 and media bridge/repeater mode
araemo
I have an odd issue that I seem to have traced to my wireless bridge/router..
I have a linux machine as my router, so my wireless routers are in AP/media bridge modes.. They're both RT-AC66Us, and they seemed to work so much better than the linksys ones I had running dd-wrt....
But as I was setting up ipv6 on my network, I noticed that while all the systems connected to the router via wired only, or directly to the AP over wireless are working fine, and all the linux systems downstream of the wireless bridge are getting ipv6 addresses and default routes set correctly.. but can't actually get any traffic to the internet. If I manually change the ipv6 default routes of one of the linux systems to my router's LAN interface global address (As opposed to its link-local address), suddenly those devices can connect.. and if I change the route back, they continue to work for a while. I THINK the client bridge is not passing NDP packets properly, but I don't have validation of that.. I just know that if I run 'ip neigh' on my router, it shows the client as FAILED.. if I change the client's default gateway, and ping6 something, it switches to reachable immediately.
If I took the time to get some packet traces at various points (the client machine and the router at least.. though perhaps on each of the ASUS routers would be possible too, though a lot more work I think) to identify what packets aren't being passed (and where they're actually being dropped, at the client bridge vs. at the AP?) would Merlin be able to fix this?
just to confirm i'm seeing exactly the same thing in Bridge mode on my RT-AC68U. Wireless and wired clients with IPV6 work fine on the network but my wired-client behind the Bridge fails.
It gets and adress but traffic doesn't follow the correct gateway.
Currently on 378.50 firmware and also tested with the latest official firmware. No difference between the two. :(
Well, good thing I decided not to return my 66's and try 68's. I did open a ticket with ASUS - they wanted me to do a factory reset and try again.. did that, no change.. just responded to them.
append /Advanced_IPv6_Content.asp to the media bridges ip <http://192.168.xxx.xxx/Advanced_IPv6_Content.asp>
and switch ipv6 to either passthrough or native, it doesn't seem to matter which, i think both are passthrough actually in mediabridge mode as the bridge doesn't end up with a ipv6 address, but the clients beneath it all begin to resolve v6 addresses properly.
Come on, this post is more than 10 years old
and its still in the top 10 search results for the query "asus bridge ipv6" (as a sub result), and is still an issue today on hardware now, why create a new thread. infact i'll update the other result just to spite you.
