As part of testing why the 386 based builds are unstable in my configuration on my RT-AX56U, I noticed that on the 384.18 build that IPv6 works great and
1) I have 9 devices with LAN side IPv6 addresses and
2) the SYSTEM LOG -> WIRELESS matches the SYSTEM LOG -> IPv6, meaning that the LAN side IPv6 addresses in the WIRELESS log also appear in the IPv6 log and for that matter the routing table.
With earlier usage this month of 386.2-2, 386.3-2 and 386.4 alpha 1, I noticed that I would at most get 1 LAN side IPv6 address assigned and that address never appeared in the IPv6 log. So I decided to go back to 386.1 to see if IPv6 worked on the 1st 386 build using Native, Prefix Delegation, Stateless as my configuration and without use of Stubby.
What I found is that IPv6 using Native, Prefix Delegation, Stateless is broken on all the 386 builds going back to even 386.1. Running 386.1, the system correctly assigns both the LAN IPv6 Address, the Prefix Length and LAN IPv6 Prefix (as shown in IPv6 settings) so it should work on the LAN side even though it does not. If you are also using IPv6 using Native, Prefix Delegation, Stateless as your configuration please check to see if the router is assigning LAN side IPv6 addresses.
Here is the only IPv6 address in the WIRELESS LOG on the 386.1 build (and same result on 386.2-2, 386.3-2 and 386.4 alpha 1):
In the IPV6 log, no IPV6 addresses are reported:
So in short, IPv6 Native with Prefix Delegation & Stateless as in my configuration appears NOT to work correctly on any 386 based build as LAN side IPv6 addresses are not assigned. When I use the same function on 384.18 I get 9 devices with IPv6 addresses assigned on the LAN side and all the logs match (WIRELESS, IPv6, ROUTING TABLE). @RMerlin sharing this as there does appear to be a bug on the 386 builds with IPv6.
