IPv6 Passthrough vs Flet's
  • Thread starter Thread starter Deleted member 22229
  • Start date Start date
D
Guest
Ok trying to get IPv6 working after setting my ATT NVG-599 to IP-Passthrough mode IPv4 works great and so does IPv6 if i set my 3100 to IPv6 pass through, all though i doubt this mode is safe as the gateway is just sending the v6 packets to the Asus and the firewall is bypassed.
So i started playing with the 3100 GUI and nothing would work for v6 until i set it to Flet's mode then v6 works so far as intended. The thing is i have no clue what Flet's mode is and more importantly does it allow my 3100 to use the IPv6 firewall and not just bypass like passthrough mode.
Anybody have any ideas. Merlin ?? Any v6 experts out here. I wont use V6 if im not sure its running through a firewall.
I have AT&T U-Verse via an NVG589 set to IP-Passthrough and my RT-AC87U works great when IPV6 is set to Native. I am surprised your setup isn't working in Native mode.
Nope no dice with native. Can you post your v6 configuration on your Asus router ??
