Ipv6 Ping
Shonk
I have been messing with ipv6
and all is working well
apart from ping replys
i have respond to ping replys enabled
This is a 6in4 tunnel btw via tunnel brokers
any idea how to get ping replys working
IPv6 is routed, not NATted. Those pings are sent at your computer, not your router. Check your computer's firewall.
thanks
i checked the firewall earlier and reply to icmp6 was enabled for the profile
just double checked by turning off the firewall temp
and its replying now ..
