D
Darknessrise
Guest
In other words, does raising your router always produce better results?
It may sound a little silly, but I'm trying to cover my neighborhood. Not because they're going to access it, but I want their networks to change channel away from mine which wouldn't be possible if they can barely see my network.
We live on a very hilly area. To the left and in front, it goes down and to to the right and back, it goes up.
I had my RT-N66 a little over half way up the wall on the second floor right next to the wall facing where the terrain begins to drop. I have my center antenna slightly tilted back to make it more flat with the hill and the two side antennas facing to the left and right.
I now tried to raise it up a little bit higher(its antennas are now a few feet from the ceiling).
Is there a point where raising it too high would make a drastic difference(in a bad way) when you're trying to cover something below and above. Most of my signal goes down it since that's the side of the house it's located at.
