elrengo
Hi!
I've in my home two Asus Wireless Router: RT-AC3100 as primary router and RT-AC66U_B1 as AiMesh node. They are connected via cable. LAN port on AC3100 to WAN port on AC66U_B1. I've a laying under the floor that connects them. It's better connection than Wireless and works great.
AC-3100 is using an Asuswrt-Merlin Firmware but AC66U_B1 is using an Asus stock firmware. I found that recommendation on Merlin website. Both devices are with firmware updated: AC3100 (384.17) & AC66U_B1 (3.0.0.4.385_20433-g3f7796b).
I can connect with both devices through SSH with the same user and password seted on primery router (AC3100).
I Attached a USB3 HDD on USB3 port of the AiMesh node (AC66U_B1). The media is share through DLNA in all my network. Is possible to see videos in that HDD in my SmartTV (Samsung) and Media Center (WDTVLIVE).
But when I require connect to SMB Shares through Windows is not possible to connect. Requires always user and password. When I use the same user to login to admin website, SSH & Samba in AC3100 and SSH in AC66I_B1. I try from Windows 10 and other laptop with Windows XP on Windows 10 is installed SMB/CIFs Client 1.0.
Can help me to connect and have read & write in the resource connected in my AiMesh node.
Thanks in advance!
elrengo
Thanks in advance!
elrengo
