Is it possible to always mount 3 disk partitions in the same order?
spanjap
I have a 256Mb SSD connected to my RT-AX88U router with 3 partitions (Ext4 with journaling):
- backups
- entware
- swap
When I reboot the router it's always randomly disk-checked (Is enabled in AMTM) and mounted.
I tried to get it in always the same order with creating a fstab.postconf file in /jffs/scripts/ but that doesn't matter.
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
# entware partition:
pc_append "UUID=9d6dde4d-ec65-4207-ae70-5f47a7c97b58 /tmp/mnt/entware ext4 defaults 0 2" $CONFIG
# swap partition:
pc_append "UUID=feed737e-4108-4698-9298-3115ab1ad581 /tmp/mnt/swap ext4 defaults 0 1" $CONFIG
# backups partition:
pc_append "UUID=9cced663-0c6f-4d69-863c-532a8ffb1583 /tmp/mnt/backups ext4 defaults 0 0" $CONFIG
Is it possible to always disk-check first entware then swap and at last the backup partition?
- backups
- entware
- swap
#!/bin/sh
CONFIG=$1
# swap partition:
You may find it easier t do a full override of fstab: https://github.com/RMerl/asuswrt-merlin/wiki/Custom-config-files
With disk-check, it's likely called on pre-mount - you may be able to customise it to your needs
final edit: why does the order of mounting matter?
No, the order is determined by the firmware. It's first seen first processed.
