SR-71
Asking as I just saw the AX86U Pro on sale nearby for $180. Thoughts/suggestions appreciated!
Have been using the AX3000 v1 centrally positioned in basement since 2020 and it's been mostly good but need better range and speed in outer rooms.
Relevant details:
1. Go Small: Get the AX86U Pro on sale and try meshing it with the AX3000. Will only cost $180 to try and I can return it if it doesn't improve things.
Relevant details:
- Will not be able to hardwire the backhaul between them, only 1 5GHz band on each
- ISP speeds 800/20 (actual: 800-920 DL / 24 UL due to ISP overprovisioning)
- Long single story house with finished basement; modem & router in the basement (can't move it due to running cable to office there to get full speed)
- Main objective is to improve signal & bandwidth to rooms at edges of home; faster WiFi file transfers with security features enabled would be a solid nice-to-have.
- 15-20 devices total, probably only 4-6 in active use over WiFi at any one time, rest idle/just background packets until needed.
- Since the Pro came out later, what's the likely/guessable life for supported fw updates?
- Small footprint is perfect since the current area for the AX3000 is likewise fairly small.
- Upgrade on both bands from the AX3000: AX86U Pro is 2.4GHz 3x3, 5GHz 4x4; although the 4th antenna is internal.
- How is the CPU processing speed compared to the AX3000 (thinking about file transfers)?
- Con: What's the likely impact of meshing the AX3000 on the sole 5GHz band, if the AX86U can't cover the entire house well enough by itself?
- The new 6GHz band won't help at all right now (only 1 tablet with AX6E upstairs and having 6E in the basement is likely only short-range from what I've read) - so even future devices likely won't benefit.
- Large size is problematic for where it needs to go, prefer smaller, would need to get a new table or shelf for it.
- Cost currently $529, bit pricey.
- Unknown but possible the AXE16000 would be able to cover the entire house without meshing (not a con, just mentioning it)
