Is the AXE11000 truly 3,500 sq ft coverage router as advertised?
Logi
It looks the same as the AXE7800 who is only 2,500 sq ft? How much RAM does the 11000 has? Thanks
1GB, according to the above.
3500 Sq ft? More advertising smoke and mirrors. As all WIFI router radios are restricted to the same power, in theory they all should cover the same area.
So, with that in mind, it is up to you to decide what shape, size, colour or configuration router you want on your shelf, table or wall. However, some routers, such as the AX86U Pro and AX88U Pro, do perform better than others.
depends on house construction and other factors in the house , my 1100pro and AXE 1100 covers all 3 floors of my house around 5000sq/ft
It is 3500 sq ft coverage router the same way it is 11Gbps over Wi-Fi router. :)
I doubt it using a normal US home. You would need a warehouse type plan and then hope. 2.4GHz might but not 5GHz.
It would not in my house.
