Is there a command to 'renew' the IP Address?
Gaz
Is there a way to tell the router to request/renew the ISP provided IP Address?
Currently I just disable the internet connection for 1 minute and then renable it and I normally get a new IP.
Is there an easier/better way than this and is there a way this can be scheduled. so for example it does it every night or once a week for example?
I know I can schedule reboots but I don't wish to lose local connectivity.
Love the FW and have been a long time user.
Hope someone can help. Thanks in advance.
G
I use this when im going to change routers temp
if i dont use this i have to wait 60mins for a lease
Release:
killall -SIGUSR2 udhcpc
Renew:
killall -SIGUSR1 udhcpc
Thats great. Im confused as to where i enter that though. I'm sure there used to be a field where you could enter commands but now I cant seem to find it.
Is there any way to schedule this?
Those commands are applied via telnet or another client like Putty.
As for Scheduling it, you can write a cron job .
Here is an example;
create a script on Jffs/scripts/
save it as renew-isp-ip.sh
add the following code to the script:
#!/bin/sh
then go to jffs/scripts/services-start
and add this code for the cron job
cru a renew-isp-ip "* 1 * * * /jffs/scripts/renew-isp-ip.sh" # renews Isp ip every day at 1am
Save it and reboot
the above cron example job will renew your ipp every day at i am
