Is there a way to disable EEE (Energy-Efficient Ethernet) on the RT-AX59U?
alexwp
I noticed the same question was asked for the RT-AX88U (here) and the answer was to use the "pwr" command in ssh.
I did enable ssh but when I try to run "pwr" it says "-sh: pwr: not found"
Any clues? Or any other ways to disable EEE on the RT-AX59U ?
RT-AX59U is MediaTek hardware device and the examples you see for Broadcom hardware devices may not apply to it.
I understand, thanks for that info. Question still stands though: Is there any way to disable EEE on the RT-AX59U?
