pwr config ...
[--wait on|off] : keeps CPU in sleep state without spinning
[--ethapd on|off] : Ethernet Auto Power Down Enable
[--eee on|off] : Energy Efficient Ethernet Enable (all ports)
[--dgm on|off] : Switch Deep Green Mode Enable
I need Merlin for SSH, right?See if you have this in SSH:
Code:pwr config ... [--wait on|off] : keeps CPU in sleep state without spinning [--ethapd on|off] : Ethernet Auto Power Down Enable [--eee on|off] : Energy Efficient Ethernet Enable (all ports) [--dgm on|off] : Switch Deep Green Mode Enable
No such settings in GUI. It may not survive reboot as well.
--all on|off|idle : All power saving features
--disk on|off : Disk Suspend: USB, SATA etc.
--wifi on|off : WIFI suspend
--pci on|off : PCI ASPM: Active State Power Management
--ubus on|off : UBUS DCM
--cpuoff on|off : CPU Off
--cpuwait on|off : CPU Wait
--cpuspeed on|off [speed] : CPU Speed
--xrdp on|off : XRDP Clock Gating
--net on|off [ifname] : Network device down
--phy on|off [ifname] : PHY Power Down
--eee on|off [ifname] : PHY EEE: Energy Efficient Ethernet
--apd on|off [ifname] : PHY APD: Auto Power Down
--dgm on|off : SF2 DGM: Deep Green Mode
--sr on|off : DRAM SR: Self Refresh
--avs on|off : AVS: Adaptive Voltage Scaling
pwr show
Power Management Configuration
WIFI Off Disabled
DISK Off Disabled
PCI ASPM Disabled
UBUS DCM N/A
CPU Off N/A
CPU Wait Enabled
CPU Speed Enabled
XRDP Gate N/A
NET Down Disabled
PHY Down Disabled
PHY EEE Enabled
PHY APD Enabled
SF2 DGM Enabled
DRAM SR N/A
AVS Enabled
Thank you, can I add scripts with the standard Asus FW or do I need for that Merlin, apologies if this is a basic questionNo, available in stock Asuswrt. Administration, System tab.
I remember Asus was disabling "wait" on some AX88U routers fighting with an issue. It was long ago though.
I am having some connectivity issues with MOCA devices, seems due to EEE but I am not 100% sure, testing for now@Logi, why do you want to change the default settings?
Thank you, do you know if this will survive a reboot?pwr config settings are available in Merlin for AX88U
Code:--all on|off|idle : All power saving features --disk on|off : Disk Suspend: USB, SATA etc. --wifi on|off : WIFI suspend --pci on|off : PCI ASPM: Active State Power Management --ubus on|off : UBUS DCM --cpuoff on|off : CPU Off --cpuwait on|off : CPU Wait --cpuspeed on|off [speed] : CPU Speed --xrdp on|off : XRDP Clock Gating --net on|off [ifname] : Network device down --phy on|off [ifname] : PHY Power Down --eee on|off [ifname] : PHY EEE: Energy Efficient Ethernet --apd on|off [ifname] : PHY APD: Auto Power Down --dgm on|off : SF2 DGM: Deep Green Mode --sr on|off : DRAM SR: Self Refresh --avs on|off : AVS: Adaptive Voltage Scaling pwr show Power Management Configuration WIFI Off Disabled DISK Off Disabled PCI ASPM Disabled UBUS DCM N/A CPU Off N/A CPU Wait Enabled CPU Speed Enabled XRDP Gate N/A NET Down Disabled PHY Down Disabled PHY EEE Enabled PHY APD Enabled SF2 DGM Enabled DRAM SR N/A AVS Enabled
I haven't a clue.Thank you, do you know if this will survive a reboot?
testing for now
Understood, my script question was general question, no necessarily related, if I am able to create a persistent script without having to install MerlinYou don't need a script for testing. Change the value, test before you reboot. Unlikely to be related to your MoCA issues though.
The usbmount script no longer works with stock firmware. Asus has removed it since their firmware didn't actively need it, and some malwares were using it to get launched at boot time.There is one option with usbmount, but I'm not sure if it still works with newer Asuswrt. @RMerlin knows if still usable or not. Otherwise no - no custom scripts with stock Asuswrt. I don't think you need this anyway for the MoCA issue you are trying to troubleshoot.
I look around in the standard Asus FW, and couldn't find it, maybe Merlin FW has the option? Thank you
I am having these random disconnections in the WAN port (connected to the ISP gateway via a pair of MOCA devices over Coaxial cable), that I think (I might be wrong) are caused by EEE on the AX88U, then the MOCA device close to the AX88U reacting (by shutting down the ethernet link on the MOCA LAN port) to EEE with a disconnection on the LAN port, so it is kind of a self inflicted wound:What problem are you trying to solve?
the ISP gateway is connected using 2 MOCA devices via coaxial cable with the AX88U.
Welcome To SNBForums
