I was just curious if there was an openvpn bug introduced in the latest Asuswrt-merlin release.
I have 2 openvpn client tunnels on my RT-5300 that have been solid for a couple of years. After updating last week to 384.15_0 both of my tunnels will randomly show as connected in the gui and public ip "unknown" (and the switch in the gui will be set to off). Looking at the vpn client status page it will only show one line with the endpoint its supposedly connected to but none of the other info like packets etc. If I ssh and check the vpn client status from nvram (nvram get vpn_client1(or 2)_state) the tunnel responds with "2" aka running. If I test traffic from my devices they have no internet connection. This doesn't seem to impact both tunnels at once, one tunnel can be running fine while the other is having the issue. Also I've seen this happen immediately after a reboot so it doesn't seem to be an issue with the tunnel being up for too long. I plan to roll back to my previous firmware to see if that fixes it but just wanted to check to see if this is a known bug or if something on my end is busted.
thanks!
thanks!
