Is there anyway bypassing CGNAT
silvercloud
My home connection got dynamic public ip. My outlet runs 4g modem which is behind CGNAT so i guess no port forwarding. Is there anyway if i want to look at my outlet cctv ? Maybe openvpn or something ? My home router use rtn66u
If you're behind a CGNAT, you're correct - no port forwarding - you'll have to find a solution that logs into a mediation server (e.g. what some call cloud based) if you want to view remote...
CGNAT will also break inbound VPN, so that's not much of an option either...
(CGNAT's are evil, necessary in some locations, but still evil)
Thanks for your reply. Is it possible if my home router serving ovpn server and the client connect to ovpn and make the connection keep alive. Can i access client lan from my home using that way ?
Edit : only the client behind the cgnat
You could rent a VPS, run a VPN server there, connect to it, and forward ports using that VPN endpoint.
so it never gonna work with asus own openvpn server. renting vps is about the same price as getting public ip service so i might as well just change isp
You need a remote server, not a local server. The router would act as the client.
