Is there something that I can use to do this with VPN?
ComputerSteve
So today I woke up and my VPN devices had no internet and the vpn screen showed check configuration. I contacted them and they said they are doing maintenance on the server. I want to know is there a way to set it up where if the VPN goes down or has error connecting the VPN can switch to a different server or even a different server instance automatically ? Is that something that VPN monitor does? or this script ? https://github.com/MartineauUK/VPN-Failover
Yes, also check this thread:
VPNMON-R2 v2.24 -Sep 30, 2022- Monitor your VPN connection's Health (New: AMTM, supporting WeVPN/Nord/SurfShark/PerfectPrivacy) (#2) (snbforums.com)
All i'm looking for is something like this --- So lets say client instance 1 is down... then automatically it switches to client instance 2.. Lets say client instanstance 1&2 are down then automatically it switches to client 3 and vice versa. Is that was VPNmonitor does?
VPNMON-R2 will randomly pick a client and attempt a connection. If it doesn't work out, it will just keep trying random client slots until a connection is made. It's beneficial to allocate all 5 VPN slots to VPNMON-R2. Which VPN provider do you use?
The one i'm currently using is iprovpn.
Yeah, so in your case, populate all 5 of your VPN slots with iprovpn servers, and VPNMON-R2 will do the rest to keep your connection going! :)
Does VPNMON-R2 work with x3mrouting. I seem to have a problem when I use the script & setup multiple VPN slots the routing stops working. Meaning VPN director stops routing if the client switches.
Not quite sure... When VPNMON-R2 goes through a reset, it does call a function to restart the VPN Director rules... so perhaps that would do the trick for you?
So I got VPNMON-R2 working with x3mrouting but i'm using the startup script. My question is how do I stop the script temporarily so I can edit the clients. Meaning the script keeps stopping and starting the VPN clients. Is there a command I can use to just temporarily stop it then reboot. What I keep doing is removing (sleep 30 && /jffs/scripts/vpnmon-r2.sh -screen) & then rebooting, then editing, then adding the code back.
Is there any portion here that can be automated a bit more? When you say you're "editing" after a reboot... is this manual? If not, can you insert a statement after this script to add the "(sleep 30...etc" back in?
Also... not sure how much time you would need after a reboot + edit, to get the script back up and running... but you could change the "Sleep 30" value to like "Sleep 300" if you wanted to? That would give you 5 minutes?
I guess I'm not really understanding the process you're going thru here... ;)
So I'm trying to test the servers of the clients that the script isn't picking but the script keeps changing the server. I just want to disable the script so I can change the server then re-enable it.
Is there something I could add to VPNMON-R2 that would make your life easier from this aspect? I built some compatibility into it to handle YazFi updates once a new VPN tunnel is established. Perhaps I could do something similar for this?
I think a way to startup the script without adding it to post-mount? in the way other scripts have a web interface and you can start and stop them or even have an option to start and stop them in AMTM.. Or if it is auto starting a way to pause the script so you can edit your vpn clients / start and stop other vpn clients / then restart the script. Also another good thing would be how are VPN Slots chosen add something like cycle in cascade style like from 1 to then 2 then to 3 to 4 to 5 instead of just random. I do appreciate the ping one !
How about this... I could add another command, like "vpnmon-r2 -pause", that makes the script sit back and wait until you either resume it with a keypress, or perhaps with another command, like "vpnmon-r2 -resume"? Would that work?
Also, I can certainly build in a normal cycle for VPN slot selection, like 1, then 2, then 3... round robin style. I can definitely make that happen!
I mean that would be great ! I just hope you can make the command vpnmonr2 -pause / resume work with the auto start thing at boot. Maybe also a status thing of what is happening inside the amtm script screen. Meaning so you can see if the script is active or disabled running / not running.
Moving this discussion to the appropriate thread... ;)
