Skynet Issue adding filter list help?
Joshuajackson
Hello i have an issue adding my own filter list https://raw.githubusercontent.com/Usernamenotavailableofc/skynetlist/main/asus/skynet/filter.list
it worked a couple days ago but now whenever i want to readd it or update it, i get error like then i get no blocking at all i have picture attached
Resetting works but whenever i add my own it doesnt
all of the list you are using that say "zip, gz, ,7z or csv" at the end, may be incompatible with skynet. I know the zip, gz, 7z ones are because skynet does nothing to unzip, or uncompress list.
here is an example of what lists which maybe or are incompatible:
https://threatview.io/Downloads/Experimental-IOC-Tweets.txt
http://cdn1.iblocklist.com/files/mbp6v2fvpd5qug9yg944/gihxqmhyunbxhbmgqrla.gz
http://cdn2.iblocklist.com/files/kr3cc3ym3slkt53kzjvi/usrcshglbiilevmyfhse.gz
http://list.iblocklist.com/?list=dgxtneitpuvgqqcpfulq&fileformat=p2p&archiveformat=gz
http://list.iblocklist.com/?list=dgxtneitpuvgqqcpfulq&fileformat=p2p&archiveformat=zip
http://list.iblocklist.com/?list=dgxtneitpuvgqqcpfulq&fileformat=p2p&archiveformat=7z
http://list.iblocklist.com/?list=llvtlsjyoyiczbkjsxpf&fileformat=p2p&archiveformat=gz
http://list.iblocklist.com/?list=xpbqleszmajjesnzddhv&fileformat=p2p&archiveformat=gz
http://list.iblocklist.com/?list=npkuuhuxcsllnhoamkvm&fileformat=p2p&archiveformat=gz
http://cdn1.iblocklist.com/files/khb6awgvtx9ag89djxow/dgxtneitpuvgqqcpfulq.gz
http://cdn2.iblocklist.com/files/vls356k74gg5gkwaq1q1/zhogegszwduurnvsyhdf.gz
http://list.iblocklist.com/?list=qlprgwgdkojunfdlzsiv&fileformat=hosts&archiveformat=zip
http://list.iblocklist.com/?list=qlprgwgdkojunfdlzsiv&fileformat=hosts&archiveformat=gz
http://security-research.dyndns.org/pub/malware-feeds/ponmocup-infected-domains-shadowserver.csv
e.g.
curl -fsL --retry 3 --connect-timeout 3 "http://list.iblocklist.com/?list=dgxtneitpuvgqqcpfulq&fileformat=p2p&archiveformat=gz" | gzip -d | wc -l
3174
vesus no gzip -d
curl -fsL --retry 3 --connect-timeout 3 "http://list.iblocklist.com/?list=dgxtneitpuvgqqcpfulq&fileformat=p2p&archiveformat=gz" | wc -l
173
which represents a compressed file.
e.g.
3174
vesus no gzip -d
173
i thought that too but ive removed them and still same result
Then i get this issue too Monitoring from to is all blank
When looking at your filter list link, I still see all of them in there on the bottom? You need to remove them from this file... They are probably causing a list compilation failure of some sorts.
Once skynet starts back up with a working filter list that is performing some blocks, you should start seeing stats again.
still having issues with the monitoring got filter back to work
