Issue applying port forwarding manual rules -solved-
Carlos M.
Hi, before ask, I searched for threads with same issu. I found several, few, but diferent problems.
After setup manually a couple of portforwarding rules I hit "Apply" and back to the same page with a message at the end: "No data in table"
I have the problem randomly. Some time I can create several rules applying after each one and... suddenly I get the message and loose the rules.
Hi, I solved the problem.
Just putting in recover mode and entering during recover mode to the router and after clearing the NVRAM. New firmware uploaded again and everything running perfectly.
Drastic but painless sollution ;)
Edited: 2016/01/18
I thought was solved but... the real problem was that if you want setup a portforwarding rule, the ip must be in the manual applied list under DHCP tab.
