Issue with Fios Stream TV and GT AXE-16000
Dyvurcz
Hello all. So I'm running FiOS 2gb internet/tv service thru my AXE-16000 and for some reason, all of a sudden I'm losing connection to my tv service every couple of days causing me to have to reconfigure the FiOS router as the main from the ONT. Once the tv is back up, I can then release the IP to reconnect my AXE 16000 as the main with the tv working again. I've had this setup running without issue for months, just recently started experiencing this issue. Not sure if I updated the AXE router to something incompatible with FiOS tv or what. Does anyone know if this is a known issue, and if there is a work around?
-The ONT is connected directly to the AXE Wan port via cat 7
-DHCP disabled on the FIOS router which is connected LAN to LAN of the AXE 16000
-Static IP set for FIOS CR1000B router in the AXE 16000
Any help would be appreciated.
