SwedBear
I have the ASUS ZenWifi XT8 mesh.-system set up at home (with 2 units, 1 router and 1 node). As my house is pretty big I wanted to get a third node. Unfortunately currently you cannot find a single XT8-router to buy here in Sweden so I decided to get a single RT-AX92U and use it as a node.
However I run into a issue adding it.
- The ZenWifi XT8-system and the RT-AX92U both have been upgraded with the latest firmware.
- The RT-AX92U has been factory-reset
- I placed the RT-AX92 about 1 meter from the ZenWifi XT8 router.
When adding a mesh-node from the Web UI it immediately finds the RT-AX92U and allows me to start adding it. However after a while (not sure which percentage) it fails saying it could not add it as a node. I get that error message you get (place it closer, make sure it is not already added to another system yada yada).
Anyone running this setup and have been able to add the RT-AX92U as a node? Or have had the same issue adding the RT-AX92U to another router with AiMesh? Got some suggestions what to try to get it to add as a node?
I choose the AX92U as it has AX but I can live without AX in one area of the house. If I get a CT8 instead as a node, am I correct to think that this node with handle the 2.4 and 5 GHz AC bands (in smart connect or without) while the two XT8 also still offers the second 5 GHz band? I use ethernet backhaul for all my nodes so opened up the second 5 GHz band on the XT8.
/Björn
/Björn
