mustafa803
Hi.
I am using Merlin 380.68_2 on an Asus RT-AC1900P router and I noticed something out of the ordinary...I upgraded to this software 5 days ago coming from the version 380.68...I dont know if this problem existed in earlier firmwares or not.
I normally have the 2,4GHz wireless set to channel 11. When I checked the wifi manager on my phone it showed that I was using channel 7. So when I logged into the router it said channel 11 but when I hovered over the wifi signal at the right top, the white box said channel 7.
So I went through all the channels from 1-11 and also the GHz channels one by one and I noticed this issue only in the 2.4GHz and I confirmed it using my phone.
Here are my findings for 2.4GHz when the channel is set to 20/40 MHz:
1------------1+3
2------------2+4
3------------3+5
4------------4+6
5------------5
6------------6+8
7------------7
8------------4+6
9------------5
10------------6+8
11------------7
I tried using 20MHz only and I got the following.
1------------1
2------------2
3------------3
4------------4
5------------5
6------------6
7------------7
8------------8
9------------9
10------------10
11------------11
When I set the bandwidth to 40 MHz I got the following
1------------1+3
2------------2+4
3------------3+5
4------------4+6
5------------5+7
6------------6+8
7------------7+9
8------------6+8
9------------7+9
10------------10+8
11------------11+9
Is anyone else having the same issue?
1------------1+3
2------------2+4
3------------3+5
4------------4+6
5------------5
6------------6+8
7------------7
8------------4+6
9------------5
10------------6+8
11------------7
1------------1
2------------2
3------------3
4------------4
5------------5
6------------6
7------------7
8------------8
9------------9
10------------10
11------------11
1------------1+3
2------------2+4
3------------3+5
4------------4+6
5------------5+7
6------------6+8
7------------7+9
8------------6+8
9------------7+9
10------------10+8
11------------11+9
