I am currently running the 378.55 build on a RC-AC87U and a RC-AC68U and I have noticed a problem with DNS resolution under both builds - in particular on the wireless side. I am doing nothing spectacular with either - both have had factory resets performed on them, both were running in Routing mode (though I have also noticed the same thing happen in Access Point mode).
Essentially what is happening is this;
- After ~2 days of operation under normal traffic conditions (say 2 people using the routers) I start not being able to perform any DNS resolution under wireless, in particular with the 5GHz band.
- If I have used torrents, which are high on UDP usage, the symptoms become prevalent with the wireless sooner than 2 days.
- I have tried using different DNS servers (local, Google, OpenDNS) but all cannot be reached at all.
- It is only the wireless that seems to be affected. Resolution on the wired side seems to be working fine.
A soft reboot or a flush of the DNS on the router (or the clients) will not resolve the issue. The only way I can resolve the problem is by hard powercycling the routers.
I am using several different clients (Android phones/tablets, Chromcast, TV, Windows/Linux/Apple boxes/Chromebook). The symptoms are quickest to show up on an Apple Air where you have to use Wifi since there is no fixed network lead (though I am sure that I can plug in a USB network adapter). All can connect to the wireless and authenticate successfully (under WPA2) but resolution of DNS (just about the first thing that happens after this) doesn't work at all.
On the WAN side I have a very fast 1gig ethernet pipe. So, there is definitely no issue on that side of things. I have also tried the same two routers on a 100meg feed with the same result.
I was wondering as to whether there is a UDP filter than could be adjusted (I have seen this being done on other routers in the past). Though I can't find a setting for this at all. There are TCP settings but nothing for UDP.
The MTU is set to 1500 and no packets are getting fragmented.
If anyone can offer any suggestions as to what could be the cause then I would really love to know. I have been trying all kinds of things - using the router as a DNS server (though the standard dnsmasq), using public DNS servers, etc.
Appreciate any feedback. The only thing I can trace things down to is something on the router itself since the clients work fine in other environments (and for the period of time before the router hits some sort of wall and needs a reboot) and I have used alternative routers without any issues (embarrassingly enough the ISP-provided router, which is known to be crap, performs better than the Asus!).
