I've setup my network as shown, but some of the client devices aren't connecting as expected. My attempts at setting Static Routes / VLANs have failed, can any kind souls here help?
Issues
1. Steam Link on SHIELD (192.168.50.2) normally fails to link with PC (192.168.1.4), with streaming error "Couldn't connect to relay 155.133.245.36:3478". On the rare occasion it connects, connection is extremely laggy, with Steam Link network test reporting >40% packet loss.
2. I'm based in China. VPN App on AC86U is set to tunnel international sites only, China sites should not be tunneled. Android Phone (192.168.50.3) connecting wirelessly to the AC86U can successfully use the VPN, but China IP only sites fail to load.
3. I'd like the PC to use the AC86U as it's DNS server so it can use VPN, but manually setting DNS on the PC to 192.168.1.2 or 192.168.50.1 breaks the PC's internet connection. Using DHCP, Default Gateway, DHCP Server & DNS Servers are all 192.168.1.1
Current settings
1. Wireless SSIDs are different on HN8145XR and AC86U.
2. HN8145XR set static IPs for 192.168.1.2-4. All other settings left at default.
3. AC86U uses its WAN ethernet port to connect to HN8145XR.
4. AC86U > LAN > DHCP Server
5. AC86U > WAN > Internet Connection
For those wondering why I'm torturing myself like this, I previously connected the AC86U to a TP Link optical modem in bridge mode, and this solution tunneled my VPN/China only traffic perfectly, but too many IOT devices overloaded the AC86U causing connection drops, and the PC connection to Steam Link on Shield was always laggy. This new setup is my attempt to load balance, connecting all phones / IOT devices which only require a China server connection to the HN8145XR, while the AC86U handles the devices which require a VPN, like the Google Mini, Shield and Harmony Hub. I'm trying to avoid running an ethernet cable from my PC to the Shield as they're on opposite ends of my flat, and a wireless connection is also not ideal due to the number of walls in between.
Issues
Current settings
- Enable DHCP server: Yes
- IP Pool Starting - Ending: 192.168.50.2 - 254
- Default Gateway: blank
- DNS Servers 1 & 2: blank
- Advertise router's IP: Yes
- Enable static routes: No
- WAN connection type: Static IP
- Enable WAN: Yes
- Enable NAT & UPNP: No
- IP Address: 192.168.1.2
- Subnet Mask: 255.255.255.0
- Default Gateway: 192.168.1.1
- DNS Servers: 192.168.1.1, 192.168.1.1
- Forward local domain queries upstream: Yes
