2.5 Gbps WAN isn't new tho, the RT-AX86U was the first model to come with a 2.5 Gbps port.Oh snap! Maybe time to finally get Google Fiber 2gig if it works with it.
Ah, it sure I knew that. But after looking into it, seems it needs to be an SFP WAN port i think.
When is it coming out ?It's been two busy days, but work is almost done now on some new devices!
First teaser:
It is nice to see it is a 10Gbps capable port, but is next to impossible to believe the router is a 10Gbps router.It's been two busy days, but work is almost done now on some new devices!
First teaser:
Why not? The BCM4912 is capable of it, it has two built-in 10 Gbps interfaces.It is nice to see it is a 10Gbps capable port, but is next to impossible to believe the router is a 10Gbps router.
I am not saying that it is an advance in the wrong direction, I am just not certain I would place too much stock in it yet. However, it sounds like something worth tinkering with.Why not? The BCM4912 is capable of it, it has two built-in 10 Gbps interfaces.
Quad-core ARM v8 compliant 64 bit processor for residential access point applications BCM4912
The BCM4912 is a quad-core ARM v8 compliant 64-bit processor for residential access point (AP) applications.www.broadcom.com
You probably won't get 10 Gbps NAT of course, but you can use that for LAN traffic: aggregated LAN + wifi, or uplink to a 10 Gbps AP.
And I'd be curious as to what throughput one could get over IPv6 as it won't involve NAT, only routing.
Unfortunately, I have no LAN client with 10 Gbps interfaces to benchmark things. I tried connecting two routers with 10 Gbps ports together and ran iperf on the routers themselves, but the CPU was bottlenecking iperf itself at 3.2 Gbps during that test.I am not saying that it is an advance in the wrong direction, I am just not certain I would place too much stock in it yet. However, it sounds like something worth tinkering with.
So might adguardhome users ....Here's a teaser for a second router, before I head out to bed
(Diversion users might like that one...)
yup i will xDSo might adguardhome users ....
What does this mean?(Diversion users might like that one...)
with 2 gb ram should do away with swap.What does this mean?
(No more swap file on USB flash drive needed?)
Just means you will be able to hold more block domain entries in memory.What does this mean?
You may still want a swap to avoid OOM situations with higher size blocklist and memory hungry applications.with 2 gb ram should do away with swap.
Welcome To SNBForums
