Join to Wireless network with CLI
mmbonsai
Hello Guys!
I'm working on an RT-N66U for a while and try to join to a wireless network which has encryption but could not succeed.
If I try to join to an open wifi network it works after the following commands:
udhcpc -i eth1 -s /tmp/udhcpc -O33 -O249
wl ap 0
wlconf eth1 up
wl -i eth1 join MyNetwork imode bss amode open
At this point I'll get an IP address but it will not be assigned to the interface. So I have to assign it manually with the following command:
ifconfig eth1 OFFERED_IP up
To join to an encrypted network I tried the following:
wl -i eth1 wpa_auth 0x80
wl -i eth1 wsec 4
wl -i eth1 join MyNetwork key 64_LONG_HEX imode bss amode open
From AP site I got the following log:
Dec 1 15:37:21 onebox hostapd: wlan0: STA 70:8b:cd:c6:d0:e0 IEEE 802.11: authenticated
Dec 1 15:37:21 onebox hostapd: wlan0: STA 70:8b:cd:c6:d0:e0 IEEE 802.11: associated (aid 1)
Dec 1 15:37:23 onebox hostapd: wlan0: STA 70:8b:cd:c6:d0:e0 IEEE 802.11: authenticated
Dec 1 15:37:23 onebox hostapd: wlan0: STA 70:8b:cd:c6:d0:e0 IEEE 802.11: associated (aid 1)
No authentication and handshaking, do you have any idea what is the correct way to join an encrypted wifi network through CLI?
(AsusWRT-Merlin 380.69 alpha1)
I tried to catch the call of the wlconf/wlcconnect/wl commands but they are on read-only filesystem so can not create any dummy runnable to log the parameters.
I wrote this script to track ip/iptables command invocations. You should be able to modify the script to track your desired commands.
/jffs/scripts/Trace_cmd.sh
e.g. Change line 35
ip|iptables)
to
wlconf|wl)
then set up the command tracing
./Trace_cmd.sh   wlconf
./Trace_cmd.sh   wl
#!/bin/sh
VER="v01.01"
#======================================================================================================= © 2016-2017 Martineau, v01.01
# Create a trace of command execution requests to Syslog for the following selected commands
#  ip
#  iptables
#          Trace_cmd     {['ip | 'iptables]}' [reset]
#          Trace_cmd     ip
#                        Tracing of 'ip' commands will be enabled. (Useful if called by 'init-start' ?)
#          Trace_cmd     ip reset
#                        Tracing of 'ip' commands will be disabled.
# Print between line beginning with '#==' to first blank line inclusive
ShowHelp() {
 awk '/^#==/{f=1} f{print; if (!NF) exit}' $0
ANSIColours () {
 cRESET="\e[0m";cBLA="\e[30m";cRED="\e[31m";cGRE="\e[32m";cYEL="\e[33m";cBLU="\e[34m";cMAG="\e[35m";cCYA="\e[36m";cGRA="\e[37m"
 cBGRA="\e[90m";cBRED="\e[91m";cBGRE="\e[92m";cBYEL="\e[93m";cBBLU="\e[94m";cBMAG="\e[95m";cBCYA="\e[96m";cBWHT="\e[97m"
 aBOLD="\e[1m";aDIM="\e[2m";aUNDER="\e[4m";aBLINK="\e[5m";aREVERSE="\e[7m"
 cRED_="\e[41m";cGRE_="\e[42m"
#===============================================Main===================================================
ANSIColours
# Create a substitute wrapper script to intercept the real command and write the trace message to Syslog before calling the original true command
case $1 in
 ip|iptables)
  case $1 in
   iptables)
    umount /usr/sbin/xtables-multi 2> /dev/null
    rm /tmp/xtables-multi 2> /dev/null
    umount /usr/sbin/$1 2> /dev/null
    rm /tmp/$1 2> /dev/null
  esac
  if [ "$2" != "reset" ];then
   cp /usr/sbin/$1 /tmp/$1       # Clone the original cmd
   # Create the wrapper script to emulate the original cmd
   echo -e "#/bin/sh\n\n# Fake '$1' command - wrapper script (Created $(date) by $0)\n"          > /tmp/fake$1
   echo -e "echo -e \"\e[33m\"\n# Write trace message to Syslog and console display terminal"   >> /tmp/fake$1
   # logger hates '-' chars in the string to be printed!!!!!!!
   #echo -e "logger -st \"(\$(basename \$0))\" \$\$ \"**TRACE: cmd request--> $1\" \"\$*\""     >> /tmp/fake$1
   echo -e "echo -e \"\$(date \"+%b %d %T\") \$(nvram get productid) spoof.logger (\$(basename \$0)) \$\$ **TRACE: cmd request--> $1\" \$* >>/tmp/syslog.log" >> /tmp/fake$1
   echo -e "echo -e \"**TRACE: cmd request--> $1\" \$*\n"                                       >> /tmp/fake$1
   echo -e "echo -e \"\e[0m\"\n"        >> /tmp/fake$1
   echo -e "/tmp/$1 \$*\t\t\t# Call clone of required original command\n\n\nexit 0"             >> /tmp/fake$1
   chmod +x /tmp/fake$1        # Ensure 'fake' command can execute
   mount -o bind /tmp/fake$1 /usr/sbin/$1
   echo -e $cBGRE
   logger -st "($(basename $0))" $$ "Fake '/tmp/$1' wrapper script enabled - will write '$1' invocation trace messages to Syslog....."
   echo -e $cRESET
  else
   echo -e $cBYEL
   logger -st "($(basename $0))" $$ "Fake '/tmp/$1' command deleted, and '$1' invocation trace messages to Syslog disabled."
   echo -e $cRESET
  fi
  echo -e "\a\n\t$cBRED**ERROR cmd to be substituted '"$1"' not defined to be traceable!!\n"$cRESET
  exit 99
esac
Thank you very much for your help, this script worked very well but the wl/wlconf is not called during start-up. Which basically means that they are build the driver calls inside the Firmware. So I'm still not able to reconnect to a different network especially in router mode as a client.
the script needs to call the wpa_supplicant when attaching to a secure network...
Actually, Broadcom doesn't use the supplicant.....it calls it's own closed source 'nas' component (just went through that update when porting the KRACK fix)
That's right, having a senior moment, LOL...
Anyways - one does have to pass along the credentials so the WPA handshake is successful..
