SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Journalling overhead
DrTeeth
I use flash drives in my N66U 374.41 router for the DLNA server.
I have it formatted as ext2 for files >4Gb and a lack of journalling support to minimise writes to the flash drive.
Are the journalling writes a significant factor in the 'wear' of a flash drive or not?
TIA
DrT
TIA
DrT
Probably not that much, especially in your usage scenario (write once - read often media files).
I'd be more concerned if the disk was being used for intensive logging, database hosting, or similar uses that involves a lot of writes.
Many thanks Merlin.
S What WAN packet overhead settings should I use? Asuswrt-Merlin 4
